Tell me about drivers and steppers - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 25 to 36 of 64
Thread: Tell me about drivers and steppers
  1. #25
    Oct 2005
    Quote Originally Posted by Fixittt View Post
    HK is correct, you have to have a machine that is capable of utilizing the increase in microstepping. 99.9% of desktop and benchtops only benefit from high microstepping to smooth out the motion if need be. My bench top mill on the other hand costs more then my some new cars, so it can utilize the increased microstepping to its advantage. There is a % of loss but its umm.............very small LOLOLOL most wont get that, but its ok.......
    Just for the record, my jewelry mill with THK ballscrews and .9 degree steppers runs at 10 micrstepping with the keling non digital drives.
    My granite based desktop (difference between desktop and bench top is size.... think the size of a X1) its THK everything its tight and solid so it can use it.....
    AND if you are using steppers in "your highly accurate machine" it isn't all that accurate anyway. Mariss explained on the gecko forum that if you attach a laser pointer to the shaft of your .9* motor and aim it on the wall, you will see larger and smaller steps as it goes through the motion of micro stepping.
  2. #26
    Jul 2006
    so micron level machining is not accurate enough? works for me.
  3. #27
    Registered scriptster's Avatar
    Mar 2009
    Quote Originally Posted by MrWild View Post
    I actually have some positioning issues with by setup whereas the steppers skip 7 of the 8 microsteps and jump like crazy on the 8th. This really drives me nuts because it completely desynchronises X from Y and I'm getting some weird squished and deformed ovals instead of circles and if it has to change directions several times on a small and complex shape part, there's really no telling what kind of deformation I'll end up with - it all becomes just random.
    So, anyhow, microstepping may be nice for keeping the noise and dynamic load on the machine low but for accuracy as such, it may be detrimental rather than helpful, despite what the term implies.
    I'm about to mount a small mirror to the shaft and try the laser pointer trick. No space for the pointer itself but a small mirror will fit and I really only need just a fraction of the whole rotation to get the idea of just how bad the things are...
  4. #28
    Oct 2006
    I am interested in seeing a picture of this mill that you use. Do you happen to have any that you are willing to show? I have never heard of this type of machining being done successfully in a home-shop environment, but would love to see it if it's been done.
  5. #29
    Gold Member
    Feb 2006
    How have you *proven*, by direct measurement, that you're actually getting the accuracy you claim? Calculating the theoretical resolution and accuracy is all well and good, but it does not mean you're actually *getting* that accuracy and resolution on the actual machine in actual use. It is also extraordinarily difficult, and VERY expensive, to achieve true "micron level" accuracy in ANY real world machine, and it requires, among MANY other things, a temperature-controlled environment for the machine to negate thermally-induced errors, which are FAR exceed "micron level" (~10 microns per degree C for cast iron, higher for steel, MUCH higher for aluminum!). So, if you're not operating your machine in a tightly temperature controlled environment, you are most certainly NOT achieving "micron level" accuracy. And, the fact is, steppers are NEVER perfect. Microstepping NEVER creates perfect, equal-sized steps, and the higher the microstep ratio, the greater the % error in step size. The error is also highly dependent on the load, and increases significantly with increasing load.
    Regards,
    Ray L.
  6. #30
    Oct 2006
    I'd also be interested to know, if this is a hand-built machine, how you would square up the axes to achieve such accuracy. The equipment to do so would be well beyond reach of most machinists, hobbyists, etc.
  7. #31
    Mar 2009
    Quote Originally Posted by HimyKabibble View Post
    Yeah, that's exactly the point. I also thought I was getting 10 micron accuracy which would have been OK for me but looked at what's actually happening and turns out to be 8 times rougher. The biggest part of the miscalculation was to think that 1/8 microstepping is giving me 8 times the accuracy which it does not.
    In fact, I'm not too sure if there's a way to know exactly the accuracy of a machine, especially one without feedback, such as driven by steppers. You can measure some surfaces but if they are complex enough, measuring them would be a whole task in its own right. My experience has been that complex shapes is exactly where the inaccuracy starts creeping up. You'd do a few perfect rectangular cuts and then go into a series of arcs which would get all messed up.
    [B]109:24:23[/B] [I]Armstrong[/I]: That's one small step for (a) man; one giant leap for mankind. (Long Pause)[SIGPIC][/SIGPIC]
  8. #32
    Dec 2009
    Microsteps are in-between positions that may only have fractional torque holding and going to the next step and varied accuracy in positioning. The 200 full steps are pretty much reliable, half steps are decent too.
    Microstepping is for smoothness of operation. Take a big ratchet and give it 8 notches per turn and turn it fast. It's going to make a hell of a lot of noise and vibrate a ton. Take that same ratchet and give it 48 smaller notches and it will be much less noisy and feel smoother as it moves at the possible expense of the amount of torque it can hold against. It's easy to hear and feel the difference in a microstep driven motor and a full or half-step driven motor. But they may not actually move the table until a couple of microsteps are taken because they lack the full torque to move the load.
    I microstep at 8 so 1600 steps per rotation and 5 rotations per inch or 8000 steps per inch, but I only count on the machine being able to position within 0.001". In most cases it *can* position to 0.0005" but there is no way in hell it's good to 0.000125" as the microsteps per would have you think.
    ETA: I guess I missed the page 2 discussion before posting. I'll concur with the above. While I know I can get it to move 0.001" on command or very close to it. I can't get better than +/- 0.003 without going to some effort in how I approach the job. Use the whole table and it gets worse.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  9. #33
    Mar 2009
    Quote Originally Posted by photomankc View Post
    This is the core of the issue with micro-stepping while micro-machining If the CNC software is setup to assume that 1 step command = 1 step movement (and if there's no positional feedback it's not going to know it's not true) then it will issue, say, 4 steps on X, then 11 steps on Y thinking it's making a slanted line whereas in reality it will make a vertical line instead because the torque of the first four microsteps is not enough to actually physically move the table in X direction.
    By the way, is it possible with EMC2 (or some other CNC software for that matter) to make sure it does not issue a step command unless the movement needs more than 8 steps? In other words, if I wanted to still use the smoother movement afforded by microstepping but did not want to allow for random and unpredictable movements on single micro-steps?
  10. #34
    Dec 2009
    Hmm, If I could remember how I did it.... I think I set it up not to calculate a position beyond 0.0000 so no matter what you tell it to do it rounds up to at least 4 microsteps. It's something I vaguely remember. I'll see if I can figure it out.
  11. #35
    Jul 2006
    here is my machine.... polished granite base and column thk rails trucks and screws. I should also note that this machine setup is also used world wide in the medical field for cancer research, micro-fluidics, micro structures ect.
    I am also going to say that its not entirely the machine capabilities that can produce good quality parts, but the person running the tool.
    There is also an article written by the Department of Micro and Nanotechnology. In the article it states that and i quote.
    The step motors controlling the stage employ micro-stepping, and a XYZ resolution ofaround 1µm is achieved. The repeatability of the system, including thespindle run-out, has been experimentally found to be less than 5µm when working on areas a few centimeters across, which is the dimension typically used for microfluidic systems.
    Now I know someone is going to spout off that the accuracy error along the entire length of the screw ect ect.
    I got called out, and I delivered. I have been here a long time helping as much as I can when I can. Im not the smartest person here either. Definitely not a real machinist.
    Attached Thumbnails Attached Thumbnails Tell me about drivers and steppers-aluminum-setup-jpg   Tell me about drivers and steppers-nsk-auto-toolchanger-jpg   Tell me about drivers and steppers-nsk-installed-jpg
  12. #36
    Oct 2006
    That is a very nice machine. It looks like a MiniTech or some variant of such. I must say, however, that I thought we were talking about "micron-level" accuracy, and that is why I inquired.
    I don't know if your response was directed partially at me, but I wasn't trying to challenge you - I was only interested in seeing the machine.
