Flood Coolant... how to wire it? - Page 6
Page 6 of 6 FirstFirst ... 3456
Results 61 to 70 of 70
Thread: Flood Coolant... how to wire it?
  1. #61
    Sep 2017
    Default Re: Flood Coolant... how to wire it?
    Quote Originally Posted by john-100 View Post
    Hi Steve
    I expect both of the 2 Ground terminals (marked in post 59) will be connected to the printer port Ground and the 5V power supply negative terminal - a quick resistance check will confirm this
    assuming you keep pins 2 to 9 for controlling 4 axis
    Put my new handy dandy Klein multimeter [ cuz I broke my el cheapo Harbor Freight unit lol ] to the test, put one end on the 5v DIN rail power supply V- / GND and one the GND closest to PIN 1 - Beeep
    Moved the probe over to the GND between PIN 16 & 17 - BEEP ! So it seems commonality - I will check the LPT ports PIn assignment and find what pin the GND is on and check that further.
    Then this happens ... checking for continuity and doing my level best to keep this stuff "isolated" on the output into the C11GR from Power supplies AND out to the KBMM-125 - as per the manuals dire warnings.
    This may be supposed to be happening - Im not too sure ... kinda makes sense it would in one way - but then I really dont know if this is OK.
    Flood Coolant... how to wire it?-c11grboard_001-png
    yes your are correct about the pin 17 conflict
    relay 3 can only be controlled by either pin 1 or 17 (so pin 1 can only control relay 3 or the SSR ?)
    but the charge pump needs to use pin 17 !! ( had forgotten about that)
    Well PIN 1 is now wired to the SSR for coolant power and the Jumper is set for Relay 3 to use 17 AND .... SCHP jumper is set to Enabled - so I hope its ok as is. My luck - not so much.
    the PWM to analogue converter is connected to pin 14
    if you select international mode
    pin 14 also switches on relay1
    pin 16 can control relay 2 , which you can use for some thing other than reversing the treadmill motor
    John
    with my pipe dreams of using Mach3 and this board to magically reverse the motor shattered by reality and revelations gleaned here in this thread - Ive moved onto a forward only, uni-direction reality :-) I shall try and exist in a threadmilling universe devoid of rigid tapping [ for the time being ] ... So, that leaves me with Relay 2 and PIn 16 ...
    Honestly still havent been able to fully wrap my head around the whole US vs. Int'l Mode and why one even needs these two setups / configurations? Thats said based upon my situation here with ports pins and controllers etc ... you feel like my best option for this is the INT'L settings? Im really trying to understand their purpose - will do some research and C11GR manual decryption...
    Thanks again sir - gentlemen and scholar and all that ...
    Steve
    Attached Thumbnails Attached Thumbnails Flood Coolant... how to wire it?-c11grboard_001-png
  2. #62
    Registered john-100's Avatar
    Mar 2007
    uk
    I suspect the US v International thing is for historical reasons
    with 2 groups working independently in the US & UK
    I guess there was a 50: 50 chance they would decided to control the motor the same way or not
    first relay for forward and second relay for reverse
    or
    first relay for on / forward and both relays for reverse
    if the C11G has the same printer port connector wiring as the C10 BOB
    I would expect the metal shell and pins 18 to 25 to be connected to the negative 5V terminal and the printer port ground
    pin 17 is not connected to pins 18 -25 on the BOB as you normally expect but is used to detect the printer cable is connected
    John
    PS
    In the past I have had to double check when working on US made equipment
    like Ampex VPR2 one inch video recorders and Grass Valley vision mixers (you call vision mixers switchers in USA )
    the old UK mains wiring was red = live (240V) & black = neutral
    while the US wiring was white = neutral and black = live (120V)
    NOTE- the earth leakage currents will be reduced when connecting an EMI filter
    to the American 240V mains supply if your machine can be connected that way
    Flood Coolant... how to wire it?-emi-filter-jpg
    compared to the unbalanced US 120 or UK 240V supply
    Flood Coolant... how to wire it?-emi-filter-unbalanced-supplies-jpg
    here in the UK I don't know who the bright spark was that decided to adopt the european wiring colour codes
    but now 3 phase wiring has changed from red, yellow blue for the 3 phases plus black as the neutral
    to the new colours that are now brown , black , grey for the 3 phases and blue as the neutral
    OK unless the building has a mix of old and new wiring !!!!
  3. #63
    Dec 2005
    When you get your smoothstepper you can use a 2nd breakout board. So don't be too worried about running out of pins on this BOB. You can just get a cheap one without all the relays, charge pump, and 0-10v out. Like the c10s or c13.
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  4. #64
    Sep 2017
    Quote Originally Posted by skmetal7 View Post
    I have a C10 in my box o' goodies - I had no plans to use - LOL guess that could work eh ? Happy day!
    Ive got this one - it says C10 R 11.1
    Flood Coolant... how to wire it?-img_20170921_154709515_hdr-jpg
    Attached Thumbnails Attached Thumbnails Flood Coolant... how to wire it?-img_20170921_154709515_hdr-jpg
  5. #65
    Sep 2017
    Update 12/30/2017 : Big Boy Pantalone's ON - Controller Box Power ON - "It's Aliiiiive!"
    NO/None/Nada... wicked, not so magic smoke either !!!
    Hats off to all the kind gents who gave enlightenment, wisdom. confirmation, inspiration and had patience putting up with so many of my rookie DAQ's.
    SKMetal7
    CNC4XR7
    BIG BIG john-100 [ man ...what an ACE! ]
    Automation Technologies
    CNC4PC
    .. many others Im sure
    Humbled, Happy moment ... its all working and not smoking. Still a good ways to go yet but major milestone here...
    Spindle Key Lock out switch - works like a champ
    E-Stop - does its duty like a Boss
    C2 - 110v Contactor does too [ man that thing is kinda violent - lol
    Holding circuit / safety feature - rocks it - Sam - CNC4XR7 - you da man brother - great setup
    Remote Panel [ yellow rectangle box ] working good - needs a coolant on / off rocker switch / a 90* liqui-tight cable gland / and a DIN or other type plug to finish off a few loose wires... WOOT ... That thing is a Cable / Conducter-A-Palooooza
    Ive got a rather strong audible Clicking / Buzz coming off the C11GR BoB though - its Relay 3.... Which I may have a conflict due to the enabled SCHP - as it uses PIN 17 ... and Relay 3's jumper set to PIN 17 .... Relay 3 alternatively can be jumpered to PIN 1 [ PIN 17 or 1 are the only two options ] - but I have PIN 1 and a GND setup to control Coolant Power via SSR Relay.
    Something is funky though ... as - when I disconnect the KBMM-125s main AC Line IN to the KBMM-125 - the Buzzing Sound ceases. All this of course makes the assumption that this card is NOT supposed to be "buzzing" ...
    Flood Coolant... how to wire it?-20171230_130040-jpg
    Attached Thumbnails Attached Thumbnails Flood Coolant... how to wire it?-20171230_130040-jpg
  6. #66
    Mar 2007
    uk
    if you are using pin 1 for the SSR and pin17 for the SCHP
    the third option is just take off the jumper for relay 3
    John
  7. #67
    Sep 2017
    John
    Thanks John ...
    Just tried that ... still buzzin. Jumper selector for Relay 3 - is bare - no jumper on it at all ... still buzzin.
    Red Light behind Relay #2 is lit RED.
    I have SCHP enabled atm ... and no Mach3 setup or connected at Parallel Port - DUOH! I shall disable SCHP for the moment and see what I get.
    more to follow...
    Thanks man
  8. #68
    Sep 2017
    Quote Originally Posted by MiniSoCalCNC View Post
    Thanks John ...
    more to follow...
    Thanks man
    SCHP disabled .. yields same results buzzing and red light on relay 2...
    Currently set INT'L mode ... gunna try US and see if that shuts one of these relays up :-)
  9. #69
    Mar 2007
    uk
    relay 2 and not relay 3
    2 questions
    how have you assigned the signals on pins 14 & 16 ??
    and have you set the jumper to US mode or International ??
    it looks like the C11G will become another project like the older C10 I did this from online photos
    Flood Coolant... how to wire it?-c10-o-jpg
    the circuit made it possible to see how it worked without having a board to test
    and add a resistor or two to answer a question when there was a conflict when most inputs required the jumper on pullup
    but one required pull down !!!
    john
    PS
    relay 2 is on in both modes when pins 14 & 16 are high (high is +5V)
  10. #70
    Sep 2017
    2 questions
    john
    Ding Ding Ding ... we have a weiner !!!
    Switched the jumpers over to US Mode - nothing wired to Relay 2 so ... I guess my slow process of deduction and your ace knowledge of a smoke free environment ... ended up near the same place.
    She's no longer making a PEEP ! No RED light for Roxanne or Relay 2 ....
    Hurrrray !
    I think we have it sorted for the most part ... more voltage testing ensues and updates to follow.
    Well done Circuit Maestro John
