New Machine Build Small, aluminium cutting mill
Page 1 of 4 1234 LastLast
Results 1 to 12 of 41
Thread: Small, aluminium cutting mill
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Default Small, aluminium cutting mill
    I have been havesting E-Bay for the last couple of years, with the intention of making a small mineral epoxy framed gantry mill.
    I have:
    4x 340mm HSR15's (dual blocks per rail)
    2x 280mm HSR20 (single long block per rail)
    3x ground C2 ballscrews (each about 300mm or a little longer)
    3x Yaskawa 60W 24V servos
    3 axis CNCDrives.com UServo + backplane/breakout board
    24V Chinese switching PSU.
    I have been mucking around designing the Mineral Epoxy bed, but don't have the equipment to mill it yet.
    Thats why I have decided to bodge up the machine with an MDF frame to get started, and get some experience. I can then recycle all the hardware onto the rigid frame in the future.
    Regards,
    Mark
    Mar 2004
    Vienna, Austria
    I normally get pretty myself tied in knots at the design phase, and decided this time to just wing it.
    On the spare of the moment, I did this design work:
    then headed of the hardware store and got them to cut the pieces of MDF:
    Got back and realised my first mistake. For some reason I'd designed 450mm long for the bed, but the rails are only 340mm long.
    Regards,
    Mark
    Mar 2004
    Vienna, Austria
    John (Microcarve) has a great way of tying the MDF sides together with threaded rod - puting the MDF under compression, so I am copying that. His thread is excellent. Thanks for sharing all that experience John.
    http://www.cnczone.com/forums/807735-post31.html
    This was routed with a little Proxxon ID/E - Pretty cool tool.
    PROXXON - IB/E
    Regards,
    Mark
    Mar 2004
    Vienna, Austria
    Along the way I started to model the mill. The model is not yet finished. The initial spindle will me my Proxxon Collet spindle http://www.cnczone.com/forums/vertic...pindles-4.html
    I have an old Deckel engraver frame with a Sherline spindle mounted on it. It is in a friends garage an hour form home.
    wrathall.com
    After gluing the spacer strips on the bed (and cutting the extra 100mm back off), I used Frankendeckel to drill the rail mounting holes (well 5 out of 6 on each side, as it needed 300mm of travel an FD only has 298mm in X) The last hole was drilled using the rail as a jig.
    The back got relieved a little to countersink the rail mount nuts.
    Regards,
    Mark
    Mar 2004
    Vienna, Austria
    While out at FrankenDeckel, I also drilled the table for the Y rail block mounting holes.
    The big holes were for mounting on a lathe cross slide. I turned up some cast iron plugs for the top and epoxied them in, then flycut them back. Looks like FD is a bit out of tram, as on one of the four the fly cutter started to rub the table.
    Regards,
    Mark
    Mar 2004
    Vienna, Austria
    Default 2nd cock up!
    When I modelled the Y Rails, I could no longer remember my login for THK, so instead of downloading thier 3D models, I just bodged up simple blocks and rails. Unfortunately, I forgot to model the blocks plastic end caps (which have the ball return circuits).
    This LH block has a screw through the table to locate it.
    The second block sticks out about 4.5mm due to the end cap, so the screw holes don't align.
    I made the screw holes nicely centered in the edge T-slots...
    ... rather than measuring the blocks!
    I guess I'll use this table eventually as a raised table on a future mill, and buy another one for this project.
    Regards,
    Mark
  7. #7
    Mar 2004
    Vienna, Austria
    The only other job I have done so far is to cut out an oval for the Y motor to fit through, and allow belt tensioning.
    I want the PSU, and servo driver to live under the table, keeping the machine compact.
    I'm going to busy for the next month or so, but lucky this project is currently very portable.
    Regards,
    Mark
  8. #8
    Sep 2005
    Indonesia
    Is that mdf rigid enough to withstand cutting force?
  9. #9
    Mar 2004
    Vienna, Austria
    Depends what you are cutting, how deep and how fast. I expect it to work fine with small mills (the spindle only takes mills up to 1/8" - 3.2mm).
    I do not expect to be able to mill steel on it with this frame.
    Regards,
    Mark
  10. #10
    Mar 2004
    Vienna, Austria
    I need some 6mm Alloy plate to mount the motors. Decided just to make some. Only took me 01:10, including set up and clean up. I couldn't drive to metalsupermarket and back in that time (especially as they are closed on a sunday).
    Heavy shrinkage on a part like this...
    Lucky I used long risers...
    Since I need to machine it anyway, I just used a scrap of plywood as a pattern, and didn't bother to put any draft on the edges. Of course it didn't pull cleanly, so there is a lot of flashing.
    Regards,
    Mark
  11. #11
    Gold Member pete from TN's Avatar
    Apr 2007
    Default Rotary...
    That is pretty damn cool man. Honestly I have watched that fellows router build and it is impressive to say the least. His design can actually rout aluminum as several of his customers have done so. The design is very well thought out and also IMHO elegant. I gotta wonder if a small CNC mill could not be made using MDF and epoxy laminating multiple layers of MDF with pressure. Surely with say eight or ten pieces of MDF cut to shape and epoxied together then sealed to keep it from absorbing fluids would result in a very rigid structure. It would also be pretty cheap to make. I know when I was a PRo-woodworker we often used epoxy to glue up IPE wood or ironwood and that was mostly because it was too dense for typical wood glues to adequately absorb into it. The Epoxy made for a super rigid structure and I know where there are about ten outdoor benches made from this stuff that are built using a stacked alternating plate design of layers and quite honestly you could probably park an M1 tank on top and it would not fold. There is also some definite vibration absorbtion qualities with MDF that can make for a useful machine base. Something the size of say an X2 could probably be made pretty easily and perform reasonably well using the same fastening properties he is using and say this laminating setup.
    What kinda furnace do you use to melt the aluminum? It looks like a pretty big part but pics can be deceiving... How much material can you get to liquify with your setup. That is something I have ALWAYS been interested in but I am not sure I have the balls to play with molten metal around the house like that...peace
    Pete
  12. #12
    Mar 2004
    Vienna, Austria
    It is only a little A5 sized furnace. I slightly scaled down the version in Anon's book Foundry Tutorial Book
    Mine was built into an old 20L oil drum.
    Have you checked out Jerry's Bamboo Router?
    http://www.cnczone.com/forums/cnc_wo...w_machine.html
    He has a comparison of the engineering properties of Bamboo vrs MDF about 2/3 the way through.
    Regards,
    Mark
