My Wholesale Tools ZX45 CNC conversion - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 68 of 68
Thread: My Wholesale Tools ZX45 CNC conversion
  1. #61
    Jan 2005
    So, if it wired correctly as diagrammed in this post DIAGRAM how does opening the centrifugal switch cut out only the start capacitor? Wired like it is, it seems like it would cut both caps from the V circuit.
  2. #62
    Jan 2005
    For example, here are the 2 diagrams. The one with the red boxes is what I'm thinking of changing it to. The only difference is the green wire running into the terminal block was initially a black wire. It was like this from the factory.
    Attached Thumbnails Attached Thumbnails My Wholesale Tools ZX45 CNC conversion-wiring-diagram-corrected-jpg
  3. #63
    Feb 2006
    Quote Originally Posted by tobybirch007 View Post
    That would be a bad idea, as the switch will no longer be able to turn off the start winding, since you've created a path through the start winding and the upper capacitor regardless of the switch state. Wired as it is, once the switch opens, one side of the line is completely disconnected from the start winding and both capacitors, so there can be no current flow through the winding.
    Didn't you get a wiring diagram with the machine?
    Regards,
    Ray L.
  4. #64
    Jan 2005
    Not that I can find, and I'm doubtful it would be of any use if I did.
    This site seems to support what I'm saying under the "2. Capacitor Start Capacitor Run" secition.
    Single Phase Induction Motors
    and that a motor like this would still have the start winding operational to control direction and smooth out the current.
  5. #65
    Jan 2005
    Also, with it wired as it currently is, what is the point in having the dual capactiors if they're both taken out of the loop when the motor starts spinning?
  6. #66
    Dec 2003
    This is what you normally would have with a dual voltage, start/run cap motor.
    Attached Thumbnails Attached Thumbnails My Wholesale Tools ZX45 CNC conversion-120_240v-pdf
    Jan 2005
    Well, I just rewired the whole thing with the diagram that I had earlier, which to my eye is the same as the one Al_The_Man posted.
    It's whirring along really well. I had to switch the polarity on the capacitor/start winding circuit (V1 -> V2) in order to get it to run the same direction as the push buttons indicate.
    I guess it's the cold weather. I can't think of any other way this happened and I only just now noticed it.
    Thanks for all the help everyone, I really appreciate it.
    EDIT: I'm assuming I can measure across the capacitors to determine if the start cap has actually been taken out of the circuit, sound right?
  8. #68
    Dec 2003
    You could measure the AC voltage across the cap to see if it were still in circuit.
    Or from each line to the switched side.
