Hoss's G0704 - Page 341
Page 341 of 344 FirstFirst ... 241291331338339340341342343344 LastLast
Results 6,801 to 6,820 of 6871
Thread: Hoss's G0704
  1. #6801
    Jul 2012
    Default Re: Hoss's G0704
    Hoss, I am using your "heavy duty digital package" so for the z axis I am using the KL-8070D Digital Stepper Driver and the KL34H295-43-8A NEMA 34 STEPPER MOTOR 906 oz-in. In the KL-8070D manual there is a discussion of 8 wire motors (i.e. the KL34H295-43-8A) having the option of hooking the motor up on either series or parallel configuration. It states that the series connection would be used in applications where a higher torque at lower speeds is needed and the parallel configuration n would offer a higher torque at higher speeds. I am thinking that I really want higher torque at lower speeds.
    I also seem to remember that you tested a configuration using one og the nema34 motors in one of your videos but now I can’t find the video.
    Which hookup would you recommend?
  2. #6802
    Jun 2011
    What voltage power supply do you have?
    The biggest reason for wiring an 8-wire motor in series is if your driver doesn't have the current to drive it in parallel. That driver can run up to 7A, and the motor only needs 6.1A in parallel, so sticking with parallel is probably your best bet. Also the torque charts on the automationtechnologies website show the motor being stronger across the range in parallel when run from 48v.
  3. #6803
    Jul 2012
    Quote Originally Posted by skrubol View Post
    I am going to run this machine with the KL-600-48 48V/12.5A Power Supply running at 48v. I did not look at the torque curves. I agree they make it fairly obvious that parallel is the way to go. Thanks for your suggestion skrubol.
    steve
  4. #6804
    Jul 2012
    Has anyone had problems with corrosion in the limit switch wires? I have tried several different coolants but after a few months of running I start getting false triggers from the limit switches. The switches themselves are sealed units, but when I check the wire connection at the switches there is corrosion, and cut the wire back and find one to two inches of corrosion inside the shielding and the wires are crap. I tried different automotive sealers and marine sealants also different coolants. Cool Mist seems to take the longest to cause enough corrosion to be a problem.
    What is everyone else using to seal your soldered wires at the limit switches?
    David M.
    San Jose CA
  5. #6805
    Mar 2013
    Quote Originally Posted by skyguynca View Post
    David M.
    San Jose CA
    I am not using limit switches just yet but I would suggest using silicon caulk to cover any area of exposed metals or areas that might allow moisture to wick in.
  6. #6806
    Jul 2012
    Thanks, but already tried all forms of silicone caulk from home depot, inside outside bathroom, they all turn to jelly in about a month
  7. #6807
    Mar 2005
    Have you tried connectors designed for underground use? The ones for phone lines can be purchased at hd. They use an epoxy
    Sent from my SM-G930V using Tapatalk
  8. #6808
    Sep 2008
    This is the switch that I have been using. The drawing doesn't show the 3 embedded wires, but they
    are 20" long.
    https://www.mcmaster.com/#8085t16/=19x6lcq
    Larry
  9. #6809
    Mar 2014
    Finally have the time blocked, etc... Time to purchase parts.
    I'm thinking real hard on going with the Automation Tech closed loop motors/drivers, and a Masso dedicated controller board.
    Figuring on this for the X and Y...
    https://www.automationtechnologiesin...-110vac220vac/
    And adding their largest closed loop motor/drive combo for the Z - I drill a LOT of holes...
    Anyone do anything similar? I am also planning on picking up a Chicom harmonic drive setup, pitching the 23 motor that comes with it, and using one of the closed loop 23 setups...
    Basically, I want accuracy to engrave small characters, combined with enough power/guts to do a lot of up/down pecking with the Z...
  10. #6810
    Lost z-steps has never been an issue while drilling, stalling the spindle however is.
  11. #6811
    Jun 2011
    That kit seems to come out to about $200 more than it's components.. Am I missing something?
  12. #6812
    Mar 2014
    Yeah, I think that they're figuring in motion control/breakout... Or something. I'll be buying the individual parts anyway...
    I'm not so worried about lost z steps while drilling as I am about overheating things as it pecks up and down through about 60 holes, some fairly deep, per part... Especially if I hang a heavier motor/belt drive on the head...
    I'm wondering what ratio will be best for the harmonic drive too... I'm guessing that a 100:1 will have less torque strength than a 10:1, right? I can just imagine stripping the teeth off the gears if I get carried away with cutting while turning...
  13. #6813
    Member cd_edwards's Avatar
    Sep 2011
    canada
    Haven't quite got to the full CNC of my G0704 clone (King Industrial KC VS20). Last couple of days, I decided to take it apart some what and remove some of the chinese goop all over.. One thing I noticed with my y Axis is I have a little bit of play and the front bearing mount is some of the source of it. it seems that, the inside bearing is slightly below the pocket and has some slop between the front of the base and the bearing mount. Should I be worried about this slop? I'm getting play of about 6 ticks of 0.002" according to the dial. My DRO's do not tick over during this amount of play. On another note though, everything is now silky smooth moving. it's easy to move the Y axis using the handle. Z is no longer the pain it used to be. Right now I've got X and Z hooked upto stepper motors in preparation for a CNC move. One thing I was thinking of doing in the meantime, is to create an arduino program for moving the X axis. Wouldn't be hard to hook it up with a rotary control for speed, a couple of push buttons for forward/reverse and possibly a limit setup. Been looking, but I haven't seen anything like this being done before..
    Colten Edwards [URL="http://www.cncsigns.ca"]http://www.cncsigns.ca[/URL]
  14. #6814
    Jun 2011
    Quote Originally Posted by cd_edwards View Post
    So you've got .012" of play on the Y? That's not terrible for a manual machine, but it is likely to cause problems for CNC. It does have ball bearings, or are they just bushings?
    I think what you're describing is basically a stepper driven power feed. I think I've seen cases where people have done similar, but few do because it's most of the way to full CNC. Also I've seen machines that have steppers on the X and Y with a manual Z, which can do full 2.5d machining, with some human intervention.
  15. #6815
    Jul 2012
    Default Re: Hoss's G0704 - C3 board, mach 3 not seeing rpm
    I have a c3 board I put on the g0704 with a different controller a d4gs, I need it for mach3 to control the spindle speed. The led on the board is flashing in time with the slot on the timing wheel, when I turn the spindle on the rpm indicator jumps up to 38 or so then goes to 1 and stays there no matter what rpm I run the spindle at manually.
    I have the index turned on, to the right port and pin, board is set to low and open collector and have tried ttl also but mach 3 is not interpreting the signal correctly, I have spindle sync on and spindle averaging too.
    Help please?
    David M.
    San Jose, CA
  16. #6816
    Jul 2012
    When I check the diagnostic screen, the index occasionally blinks, and at random
    David M.
    San Jose, CA
  17. #6817
    Registered CFLBob's Avatar
    Apr 2016
    Help please?
    David M.
    San Jose, CA
    Count me among the folks who would like to help, but don't know enough about the boards.
    What it sounds like to me is either a real intermittent connection or something that makes it not work as well as it should. I'm not familiar with what C3 board or D4GS is, but a quick search showed me a C3 Index Pulse board from CNC4PC for motor control, and that sounds like what you're doing. Is that what you mean? On page 6, the manual talks about needing an external pull-up resistor. That could do what you're seeing, so is it configured?
    It would help me if you could tell more about those cards, what they are, maybe link to the user manuals.
    Bob
    Shop-built 4 axis CNC Sherline mill with A2ZCNC extended XY and CNC Sherline lathe.
    4 axis CNC Grizzly G0704 - based on Hoss' plans Manual Sherline 4400 and LMS 3540 lathes
  18. #6818
    Jul 2012
    OK, I got it figured out, Arturo had a few suggestions but I am not sure they work with Mach3 or 4 at all, they just keep a record of what works for different users who figure out the problems. The Mach forum was totally useless, alot of people have posted these problems and no one from ArtSoft ever replied.
    I spent about 30 hours going thru the software/drivers that came with the ESS boards, and Mach3, numerous combinations, kept a real good record on what I did and how it failed. I did figure it out eventually.
    I now know the spindle sync and such in Mach3 Mill does not work so give that up.(they should not even put it in if it does not work)
    To get the C3 board to work accurately and reliably with Mach3 Mill, using the ESS with the C10 boards you have to have 2 slots on the timing disc, 180 degrees apart, use the index not the timing in ports and pins then set your prescale in the ESS configuration software to 2, then you will get very accurate RPM's and then you can run the calibrate spindle and it will get within 40+- rpms thru your rpm range, do not forget to set min and max rpms in your spindle pulley.
    David M.
    San Jose, CA
  19. #6819
    Jul 2012
    Default Re: Hoss's G0704 - Anyone heard from Hoss lately?
    I had dropped a few emails to hoss over the past few months and had not heard back. He is pretty good about replying. His last post here was back in July...I hope he is ok. Anyone heard from him since July?
    David M
    San Jose, CA
  20. #6820
    Aug 2016
    I got an email from him Aug 4th.
Hoss's G0704
Hoss's G0704
