Hoss's G0704 - Page 344
Page 344 of 344 FirstFirst ... 244294334341342343344
Results 6,861 to 6,871 of 6871
Thread: Hoss's G0704
  1. #6861
    Jan 2018
    United Kingdom
    Default Re: Hoss's G0704
    Quote Originally Posted by Fastest1 View Post
    In my case it wasnt missing steps nor had any loose hardware.
    And it wasnt consistent in the amount traveled positive or negative.
    This was years ago. It was damned infuriating. Especially after running trouble free for years.
    I always suspected an automatic update but couldnt track it to anything.
    Slowing down accel etc never made any change.
    Sent from my iPhone using Tapatalk Pro
    I had issue with mine too that was PC related and affected the P-Port driver.
    Error: "MARK_FUN load NT driver"
    If this error didn't come up on startup it would miss steps every full rotation.
    You could hear the bumping noise.
    If the error appeared then it was fine.
  2. #6862
    Jul 2012
    I slowed it down , I sped it up, I changed number of steps and retuned the motor went through complete set up again. And again it was off on every rotation and it was never linear sometimes it was a lot and sometimes it was very little but it was always off and it didn't matter whether you were going forwards or backwards.
    I took the leads from my A axis driver, and connected it to the tool changer stepper motor. Now it works fine so it must have been the driver. Everything was working fine and then this driver just died. Glad I was watching it cut when it went to do the tool change or it would have been a terrible crash.
    Need to figure out a way to make a closed loop system, that's affordable, for steppers that work with mach3 so those of us with older systems can upgrade them and keep them running without having to spend a fortune on new software and Hardware.
    So now I need to buy a new driver so my rotary table can be back up and running on the mill.
    Thanks for the suggestions
    David
  3. #6863
    Member phomann's Avatar
    Aug 2005
    I've seen this happen with wood routers where dust and swarf builds up on the axes and binds it up over time.
    In these cases I disconnect the steppers and see if the axes are binding by moving them by hand.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com
  4. #6864
    Member Freeway99's Avatar
    Aug 2019
    Does anyone know where I could find the plans for the pdb 3?
  5. #6865
    Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by Freeway99 View Post
    PM sent, Merry Christmas!
    Hoss
    Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL]
  6. #6866
    Apr 2006
    Guess a PM won't work so email me at hossmachine.info@gmail.com
    Hoss
  7. #6867
    May 2011
    Quote Originally Posted by hoss2006 View Post
    hoss@g0704.com is back up and running now.
    Hoss
    Thank you! I bought a g0704 2 years ago; still sitting in its crate! doh! too many hobbies, not enough time! Been watching your videos off and on for the better part of a decade! Need to free up some garage space and then get cracking on this mill!
    Sincere thanks for all your effort!
  8. #6868
    Member diyengineer's Avatar
    Feb 2010
    USA-WA STATE
    Hoss
    Emailed you!! Haven’t spoke to you in forever. Hope all is well.
  9. #6869
    Apr 2006
    Don't have to store on the website for the DVDROM downloads anymore but they are available by request, hossmachine.info@gmail.com
  10. #6870
    Member Balbz's Avatar
    Sep 2018
    Sent you an email about getting a copy of the PDB3 (purchased the whole set of plans many years ago, finally getting to build the machine).
  11. #6871
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Quote Originally Posted by Balbz View Post
    Its possible that email address is outdated. See my reply in this thread:
    https://www.cnczone.com/forums/bench...68060-cnc.html
Hoss's G0704
Hoss's G0704
