Not even close, the thread on cnczone about global warming, pollution and other such anything to gripe about topics has nearly 8000.
Just seems a thread where the trolls and arguers are given free reign.
Hoss
Gosh, you've... really got some nice toys here. - Roy Batty -- [URL]http://www.g0704.com[/URL]
nah, at least 7 good informative threads top the list higher up.
Share your files is aces.
top 10 stats are on the homepage.
Hoss
Got a nema 34 to test with the 5th axis, 1290oz/in.
It's 8 wire so I can try it both series and parallel to see which works best.
Even in parallel detuned to 806 oz/in with the 6050 driver it should perk things up a bit.
Hoss
Well wow I haven't been here in like 8 months. You really did a great job Hoss.
I have a question for you Hoss,
I want to R&D RC parts , cars air planes & boats. Do you think a CNCed G0704 will do what im looking to do?
I mostly will be doing aluminum stock .
Thanks Hoss
Watch some of the videos on my project page, it chews thru aluminum like butter.
Projects2
Hoss
I got the print and programs done for the n34 mount.
Made it down into the basement for the first time in months, that's where I got the motor.
Pulled a bunch of parts off the x2 too like the tooling plate that'll find a new home on the g0704.
Gonna have the console bought up too and remodel it.
Being lazy, don't feel like finishing the one I started.
Hoss
The 2.5:1 ratio on the 5th axis does help the 570 stepper.
The speed was the same but it did it with the weight of the power drawbar on there this time.
Hoss
http://www.youtube.com/watch?v=x7nSxvDxMy0]G0704 5th Axis Improved and Trued - YouTube
very nice work Hoss on the 5th axes.. I want to see the video of 5-axis machining at your end..
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
I've gotta say I always find your videos very interesting Hoss! Lot's of useful information!
cheers,
Ian
It's a state of mind!
With that 5 axis you could carve a pumpkin for Halloween.
Great job can't wait to see some parts getting made. You still using the ATC?
Thanks fellas!
Made the nema 34 mount and set it up today.
Didn't have the locks on and the 5th didn't cause any vibration at all, was only using a 3/16 endmill though.
Snugged the worm up as tight as I dare to get the backlash down as best as possible, will check it tomorrow.
Tried the nema 34 first in parallel then series mode.
Ran the same speed in parallel as the 570's best (it's harder to rotate now though)
Got a 20% speed improvement in series mode.
Will try a lower pulley ratio again, running 1:1 now.
The tool would be seeing something along the lines of 150 IPM right now.
Hoss
