Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 02-03-2010, 04:36 PM
coop2005 is on a distinguished road
Enhanced Pulsing causing step loss
I was pulling hair out trying to figure out why my machine was missing steps in a gcode program of a simple line at 100 ipm, but i could jog all axis at this speed and higher. Other people have had this problem with my same motor, PS and drivers and noone could give them an answer. Turns out when i turn off enhanced pulsing everything is fine. Whats the deal with this feature?? I have the 8070 drives c10 breakout and the 1200 Oz*in motors. Am i sacrificing anything significant by turning this feature off?
Old 02-04-2010, 06:49 PM
ee_t is on a distinguished road
Enhanced Pulsing, if checked, will ensure the greatest accuracy of timing pulses (and hence smoothness of stepper drives) at the expense of additional central processor time. You should generally select this option.
Whats your PC setup?
Old 02-04-2010, 07:12 PM
1GHz cpu, 1GB RAM.. looking into a new one after this fiasco. I checked the pulse train quickly with a scope, couldn't measure anything different with or without enhanced pulsing, but this is inherently a tough thing to look at with the ramp up down etc. I know the manual recommends a 1Ghz CPU. Is there any info on what processor speed is capably of achieving the different pulse rates?
Old 02-05-2010, 06:48 PM
Try the test program (C:\Mach3\DriverTest.exe).
Art posted that his 1.2GHz is able to barely achieve 100kHz, however I use 25 on my equivalent speed laptop.
Old 02-09-2010, 11:44 AM
Computer upgrade makes a HUGE difference
it turns out my 1Ghz processor wasn't cutting it. I upgraded to a 2.5 Ghz and went from 100ipm at 25000Khz not being able to run enhanced pulsing, to 400ipm comfortably with 45000Khz pulsing. the driver test checks out fine all the way to 100khz but i don't think i need to go any faster than 400 ipm at this time. Thanks for the help
New Computer Pulsing Too Fast richlandrick Machines running Mach Software 18 03-11-2012 09:14 AM
Problem: Pulsing motor on a new Harbor Freight 7X12 mini lathe hiyata99 Mini Lathe 5 10-09-2009 04:10 PM
pulsing chatter ihavenofish General Metalwork Discussion 0 08-12-2009 04:45 PM
How fast before step loss creep_pea Bridgeport and Hardinge Mills 8 01-05-2006 07:13 PM
EMC(enhanced machine control) CNCadmin LinuxCNC (formerly EMC2) 1 07-15-2003 04:18 PM
