Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Help with wiring
    Jan 2010
    Help with wiring
    Recently we purchased the following from Keling but are unable to get it to work due to our inexperience. We get a green light on the 8078 until we try to make the motor move then a red fault light. The motor is also making a high pitched noise when green light is on. John has been helpful but our inexperience is where we are lacking
    C10 Breakout board with 5V power supply
    8078 driver
    7220 power supply
    Nema 42 (KL42H)
    This is how we have it setup. We have tried a number of setup but this is how it is currently. We are just using a simple LPT program to activate and de-activate the pins on the parallel cable to get it to step.
    The KL 7220 is providing 70V to the 8078
    The KL-10-5 is providing 5V to the C10 board
    Motor is wired bipolar (series) according to the PDF on the website
    Motor blue wire to A+ on 8078
    Motor green wire to A- on 8078
    Motor brown wire to B+ on 8078
    Motor white wire to B- on 8078
    Motor orange tied to motor black
    Motor red tied to motor yellow
    C10 Pin 8 to Dir - on 8078
    C10 Pin 9 to Pul - on 8078
    Dir + on 8078 to 5V on C10
    Pul + on 8078 to 5V on C10
    C10 In/Out jumper set to [1-2] Output
    C10 Com jumper set to [2-3] 5V
    C10 2-9 pin jumper set to [2-3] Pull up
    Dip switches on 8078 set to 400 steps per rev and 2.8A according to diagram
    on top of 8078
    Thanks for any advice.
    Jan 2010
    Also, when trying to use the motor tuning section of Mach 3, we get one step before the fault light on the 8078 is activated. Thanks
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Do you have the +5 volts connected to the enable pin and the 5volt pin on the C10?
    Do you have the estop connection on the C10 jumpered?
    See attached image.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2010
    Yes. Thank you for the diagram though.
    We are officially giving up on this and it appears we are going to order new Parker Hannafin motors and controllers. They cost about $3000 more but are plug and play pretty much. That helps us simple minded people.
    jeff
    Feb 2007
    U.S.A.
    Post
    Jeff,
    Many thousands of the Keling "Leadshine" drivers are running machines world wide, you may have received a defective unit.
    Ask John to ship a replacement before you give up.
    Jeff...
    Oct 2005
    Hi Jeff
    It is very close. You set up the Mach3 properly, it will work
    www.kelinginc.net
    Jan 2010
    Thanks for all the help and phone support John but we are just unable to get it figured out. Even if when we had the parallel cable unplugged from the board the 8078 would give a fault light as soon as it was plugged in when wired in bipolar parallel. We were doing something wrong but wouldnt figure out what it was that we were doing wrong. At one time there were 5 of us working on it and no one had a clue. lol
    jeff
    Feb 2007
    U.S.A.
    Question
    Jeff,
    Did you leave ENA+(+5V) disconnected on the 8078?
    Jeff...
    Jan 2010
    We tried both ways.
    We pulled out an old Parker compumotor plus (NEMA 56) and hooked it up to the Keling C10 breakout board and are controlling it with Mach 3. It's up and running and now we just have to make and adapter plate to mount it on our timing screw machine and we should be good to go. We'll just have to make some changes to the original software that we wrote so that it will work with this new motor.
    Once we get caught up, we are going to see if we can figure out what errors we made with the 8078 and NEMA 42 motor.
    jeff
    Feb 2007
    U.S.A.
    Thumbs up
    Jeff,
    It sounds like the 8078 may be defective.
    Please keep us posted on your progress.
    Jeff...
    Oct 2005
    Quote Originally Posted by jalessi View Post
    Jeff,
    Jeff...
    We will send you another new KL-8078 to try
    www.kelinginc.net
    Jan 2010
    Thanks John. We'll definitely make another go at it.
    jeff
  • Page 1 of 2 12 LastLast
    1. Newbie- C11 Wiring
      By kostas1 in forum Automation Technology Products
      Last Post: 10-28-2009, 11:32 AM
    2. MPG wiring at x4
      By cvafiadis in forum Syil Products
      Last Post: 05-24-2008, 11:14 PM
    3. Wiring Help
      By tz1238 in forum Stepper Motors and Drives
      Last Post: 11-22-2007, 07:14 AM
    4. need help wiring
      By dtman in forum General Waterjet
      Last Post: 02-19-2007, 08:55 AM
    5. CNC wiring?
      By stdly in forum General Electronics Discussion
      Last Post: 02-18-2006, 03:44 PM
