Results 1 to 2 of 2
Thread: Keling 5010 power supply wiring
    Oct 2009
    I am getting set to wire up my Keling 5010 Power Supply. The output side has a 5 pin connector. The first two are marked "+", the last two "-" and the one in the center with a broken oval. What does the oval mean? Do I need to hook that up to anything?
    Thanks...
    Oct 2009
    Figured it out...Got brave and turned the controller on. Ran a voltmeter between the oval and the +/- leads. Read about 25V. This must be common. The broken oval must be a "C". Would be a neat way to pull 1/2 voltage from the transformer!
  1. Replies: 5
    Last Post: 09-27-2009, 09:01 PM
  2. Keling Power supply
    By judleroy in forum General Electronics Discussion
    Last Post: 08-25-2009, 01:08 AM
  3. Fuse for 5010 power supply
    By bd007 in forum Automation Technology Products
    Last Post: 04-11-2009, 04:13 PM
  4. Keling motors, drivers and power supply connections
    By Nitroghost in forum Automation Technology Products
    Last Post: 03-13-2008, 12:18 PM
  5. Keling power supply?
    By mcruff in forum Automation Technology Products
    Last Post: 09-23-2007, 10:11 PM
