Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 11-29-2009, 07:35 PM
marzetti is on a distinguished road
Need help with motor direction
I have set up my machine using the C10 board and the 4030 drivers with Mach 3. I can get the motors to turn just fine but only in one direction! I've checked and doubled-checked the wiring and the Mach 3 settings but I must be missing something. Can anyone help?
Old 11-30-2009, 03:04 AM
Tweakie's Avatar
Tweakie is on a distinguished road
I think you need to check that there is sufficient voltage change (ideally 0 to 5V) on each axis direction pin and that you have them configured correctly within Mach.
Tweakie.
Old 11-30-2009, 09:04 AM
some progress
I found the dir setting in Mach was set to 0 instead of 1. Changing this corrected the problem on 2 of the axes but my y will still only move forward.
Any ideas?
Old 11-30-2009, 10:10 AM
Tweakie's Avatar
The direction pin assignment should be different for each axis.
Tweakie.
Old 11-30-2009, 10:41 AM
Thank you Tweakie, I'll try that.
Old 11-30-2009, 08:59 PM
problem solved
Well, it turned out to be a bad parallel port. I downloaded a free port monitor utility and could plainly see that the direction pin in question was not firing. I tried another computer and it worked just fine.
How can I reverse the direction of one motor using turbocnc? jetijs TurboCNC 2 11-28-2008 06:23 PM
Motor Direction Ken Bond Phase Converters and VFD 2 11-20-2007 06:22 AM
motor moves one direction: what am I missing? boyvox Stepper Motors and Drives 12 10-10-2005 06:43 PM
Motor only moves one direction spoiledbrat Mach Software (ArtSoft software) 3 06-12-2005 01:02 PM
motor direction sixpence Mach Software (ArtSoft software) 2 12-28-2004 10:15 PM
