Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 08-31-2009, 06:42 AM
bevins is on a distinguished road
Keiling motors and G540 connections Help
Hi all,
I am looking for someone that can tell if I am wired up correctly before I power up and let the smoke out.
I have keiling KL23H286-20-8B motors and a G540.
I want to run bipolar parralel.
red/white - blue/white to G540 pin 9
red - blue to G540 pin 8
green - black to G540 pin 7
green/white - blackk/white to G540 pin 6
KL23H286-20-08B.pdf
Old 09-03-2009, 10:03 AM
dmauch is on a distinguished road
First of all you woul;dn't let the smoke out. The G540's have oustanding short circuit protection.
The wiring is correct per the data sheet but to be honest I have looked at thousands of data sheets and never seen one where the designations were done that way.
What I look for is the * which tells you the phasing of one winding to another.
so *a is connected to *c for pin 9 and so on.
Your wiring is correct. add a 2.8K resistor to pins 1 and 5
Dan Mauch
www.camtronics-cnmc.com
low cost cases for the G540
The
KL23H286-20-08B.pdf[/QUOTE]
Old 09-03-2009, 03:39 PM
Kelinginc is on a distinguished road
Dan Mauch
The
KL23H286-20-08B.pdf
[/QUOTE]
Check this drawing, it will be clear for you
http://www.kelinginc.net/KL23H286-20-8B.pdf
Old 09-04-2009, 03:01 PM
cncdzz is on a distinguished road
Now I am confused. I am working on the exact same set up. Looking at g540 docs it appears that pin 9 is -a and pin 8 is +a pin 7 -b and pin 6 +b. Which according to keling wiring diagram would mean pin 9 red & blu, pin 8 red/wht & blu/wht, pin 7 grn & blk, pin 6 grn/wht & blk/wht. Could someone please clarify.
Newbie so don't know if this is the right place to post but here goes.
thanx
Old 09-04-2009, 03:59 PM
CoAMarcus's Avatar
CoAMarcus is on a distinguished road
The phase names are names only; generally when you see a motor control labeled "A", "/A", "B" and "/B" the different letters refer to the two windings. An 8-wire motor adds a bit of confusion to this by throwing in different letters for the names of the wires. You have the right idea in the first post for the wiring.
Marcus
Newbie- Keiling KL-350-48 and G540 hookup Help FandZ Gecko Drives 10 11-08-2010 12:44 PM
Need Help!- Need Motors for G540 bd007 DIY-CNC Router Table Machines 0 03-23-2009 07:00 PM
Need Help!- Looking Stepper Motors for G540. samsagaz DIY-CNC Router Table Machines 10 03-22-2009 04:46 PM
Keling motors, drivers and power supply connections Nitroghost Automation Technology Products 14 03-13-2008 11:18 AM
stepper motors run one-way only ? connections ? pavel59 Mach Software (ArtSoft software) 3 09-09-2007 08:15 AM
