| Automation Technology Products Discuss Automation Technology Products here. |
I bought the 3-axis stepper motor package with 640 oz-in motors. I was very pleased until I tried to wire it up. My problem is that I can't get any motors to turn. I have rechecked everything I can find in the documentation. I have setup Mach3 several different ways and can't get anything to work. My question is, how can I troubleshoot the driver, or the breakout board, or Mach 3 seperatly to isolate my problem area. Is there a way I can trick the driver and get it to turn a motor just to show it works? When I power up the system I hear the motors lock and will not turn. I believe this is a good sign. How can I test by BOB for high's and low's using Mach 3? driver - KL-5056, 24V-50V, 5.6A Bipolar Driver motors - NEMA 34-640 oz-in Stepper Motors PS - 1 PCS 48V/ 12.5A, Power Supply, 110V/220V BOB - C10 Breakout board, E-Stop or Limit Switch can be wired 5v PS - 5V power supply, 110V/220V Thanks Paul |
| Hi Paul 1: check this Mach3 setup in our website http://www.kelinginc.net/Mach3Tutorial.doc 2: Did you use straight wired Cable http://www.kelinginc.net/CNCPackage.html |
| I found out that Mach3 is not compatible with most laptops. Can anyone confirm this? I am using a Dell D800. That is what I have been trying to run off of and it might be the reason for all my problems. I can't get any movement from the motors. |
| Paul, The majority of the problems with laptops and Mach3 have to do with power management features. Some are in hardware and can't be disabled easily, but one thing you can do is disable any you can find in Windows. You can look under the "Power" applet in the Windows Control Panel. Other things to watch for are shared hardware interrupts, the Windows search and indexing services and anti-virus programs. Occasionally you can get lucky and find a machine that will work as a "normal" computer and still run Mach3 correctly, but the truth is that dedicated, off-network machines run much better. My .02, --jim |
| Breakout Board, Driver and Power for nema23 - UK supplier? | mnbylcr2 | Benchtop Machines | 4 | 05-21-2009 11:47 AM |
| Need Help!- does this driver need breakout board? | dreamci | General Electronics Discussion | 2 | 09-30-2008 04:49 PM |
| Stepper Driver, Controller, Breakout board, Home switch, ????? | perolalars | General Electronics Discussion | 4 | 10-28-2007 09:35 AM |
| CNC newbie question Servo+driver+breakout board? | wolfmetalfab | Servo Drives | 0 | 05-11-2006 01:43 AM |
| Troubleshooting the OS discrete single axis board | Konstantin | Open Source Controller Boards | 3 | 08-24-2004 04:31 PM |
