Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 06-13-2009, 11:48 PM
cambosoup99 is on a distinguished road
425oz motor tuning
Just wondering what settings people are using for the 425oz steppers from keling. Maybe Keling can post some recommended settings.
currently i have the steps set up as follows in mach 3
x and y axis:
step per: 1600
velocity: 138
accelleration: 42
step pulse: 0
dir pulse: 0
z axis:
step per: 3200
velocity:138
accelleration: 42
step pulse: 0
dir pulse:0
my current setup physically:
4 keling 425oz steppers
keling 4030 drivers ( current set at 3.0 amps microstepping: 1/4)
2 start leadscrews for z axis (5 turns per inch)
5 start leadscrews for the y and x. (2 turns per inch)
running mach 3, with cnc4pc c11 breakoutboard
38v 15a antek power supply
2.6ghz dell computer
Everything seems to work fine testing them with no load. but what should i be listening for
when i tune the motors? im not sure if its right or not. I want my system to be reliable and perform good. thanks for the input.
Old 06-20-2009, 07:26 PM
nobody knows?
Old 06-20-2009, 07:52 PM
ger21's Avatar
Every machine is different, so you can't really go by someone else's settings. What you want to do is set the accel and velocity as fast as possible, with enough safety margin so you never miss steps. Faster accel at the expense of top velocity is usually the best way to go.
Old 06-23-2009, 03:40 AM
That didn't answer my question. The question was what should i be listening for or looking for when i tune the motors?
Old 06-23-2009, 08:11 AM
ger21's Avatar
Measure the distance traveled, and make sure it's accurate. Increase speed and accel until it's not, then back off.
Old 06-23-2009, 11:45 PM
thanks i'll try that
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Motor tuning br1 Mach Mill 1 02-28-2009 07:38 PM
Need Help!- Help with motor tuning harrisam DynaCNC 8 05-09-2008 08:17 AM
Motor Tuning dwacker DIY-CNC Router Table Machines 8 04-30-2007 09:50 PM
Motor Tuning cookja01 Machines running Mach Software 1 03-07-2007 02:27 PM
