Results 1 to 11 of 11
Thread: Warming problem with motors KL23H286-20-8B
    Jun 2009
    FI
    Hey,
    I pardon if this question is answered allready in somewhere in this forum but I didn't find answers so I gathered my bravehood and asked from you,
    So, I have Keling KL23H286-20-8B motor and driver KL-6056 for the motor and I'm using Mach3. Why does the motor warms up a lot? On the movements and ALSO on idle position. I have set the current peak from the dip switches first to 3.2A and i also tried 2.7A and it helped a bit. My motor is connected as a bipolar parallel mode. I have a thought that the motors maximum current per phase was about 3.3A? What is the problem?
    Or is the problem caused the Mach3 which I can't yet use very goodly?
    And a another dump question, what is the easies way to increase stepper motors speed from Mach3? I test my motors in table so I haven't yet calculated correct values for the Steps per mm field. I use 1/32 microstepping.
    Thanks for answers in advance!
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    Steppers run warm to hot on most drives, it's normal. You need to do your motor tuning in mach3 and have the correct settings. Set your kernel speed to the fastest that will work on your pc.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jun 2009
    FI
    Are my current peak dip switch settings setted correctly for this motor in where position? I mean should it really be setted to 3.2A?
    Then the motors is really hot, almost to hot to keep on hands? That could not be normal?
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Post
    Htman7,
    What position is dip switch "4"?
    Dip switch "4" controls the idle auto current reduction, it should be off in order to reduce idle current and motor heating.
    The motors will still get very hot if you don't have them mounted to something that will dissipate the heat away from them.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jun 2009
    FI
    When I tested it on 3.2A it was on Full Current position, I don't remember was the full current settings at on or off position but I would change it. I think that might help a lot.
    Is there any other tips how to decrease heat in motors?
    The mounting to cold iron should be real objection but in my test procedure it is hard to do so.
    Jun 2009
    FI
    I setted the idle current mode to "half current", and added current peak level to 2.7A, because of parallel connected motor specifications says that the phase current is 2.8A???
    After all, it still warms a lot, Why??? Specialists...????
    Mar 2003
    Shelby Twp, MI....USA
    Gecko's FAQ says that motors wired parallel run much, much hotter than motors wired in series. It's just the way steppers work. If they are less than 150°-180°F, then they're fine.
    Feb 2007
    U.S.A.
    Post
    Htman7,
    Average Stepper Operating Parameters
    Temperature Rise: 80°C (176°F) or less as measured by the change in resistance method when both phases are energized with constant rated current.
    Motor Case Temperature: 100°C (212°F) maximum.
    Ambient Temperature Range: -40°C to +65°C (-40°F to +149°F).
    Ger21 is 100% correct.
    Jeff...
    Feb 2007
    canada
    What is your power supply voltage ? It may be too high especially in parallel mode.
    Also are the steppers mounted to an aluminum (not steel) frame ?
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Apr 2009
    Greece
    How could we count a motor's surface temperature?
    Also, in what motor's surface temperature should we mount some cooling stuff on it?
    Feb 2007
    U.S.A.
    1. Need Help!- need help, i got a problem with Y servo motors axis.
      By tarikk in forum Servo Motors and Drives
      Last Post: 05-06-2009, 06:53 PM
    2. Someone is Stealing the Warming!!
      By fizzissist in forum Environmental & Alternate Energy
      Last Post: 04-01-2008, 12:32 PM
    3. Replies: 11
      Last Post: 03-03-2008, 07:33 PM
    4. HOT motors. Voltage problem ?
      By DJ Morrow in forum General Electronics Discussion
      Last Post: 11-25-2005, 12:41 AM
    5. Warming up steppers
      By Dylwad in forum Stepper Motors and Drives
      Last Post: 02-23-2005, 04:50 PM
