| Automation Technology Products Discuss Automation Technology Products here. |
| I finished getting AC to my control box last night. When plugged in, should the power supply fan be on? Or is it on a thermostat? Question #2...I have the C10 BOB and I unhooked the jumper wire from the 5V to EN replacing it with a switch. With the switch in the on or off position, the light on the board is still lit up. Does the light mean that the board is enabled? Or does it just mean that it has power and can be enabled. An easier way to ask that question, I guess, would be...Is the light on whether the board is enabled or not? Thanks, Rooney |
| Rooney, The LED on the C10 remains lit as long as your computer is on even if the power to the C10 is turned off. If you have a Meanwell power supply the fan is on a thermostat. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| CNC mill questions - thrust bearings, leadscrew mounting, general questions | tonofsteel | DIY-CNC Router Table Machines | 8 | 02-03-2012 03:42 PM |
| Brass vs Aluminium Vs Steel, questions, questions and questions... | alexccmeister | General Metal Working Machines | 25 | 08-15-2011 12:40 PM |
| EZ-Cam questions | aaron p | General CAM Discussion | 25 | 11-22-2008 06:59 AM |
| Newbie- VF-0 Questions | rawen2 | Haas Mills | 2 | 08-12-2008 05:14 PM |
| Questions about TIG | jrc347 | Welding, Brazing, Soldering, Sealing | 8 | 11-10-2006 09:40 PM |
