Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 05-03-2009, 08:19 PM
Rooney is on a distinguished road
Question 5 volt positive and negative??
The wiring diagram says + and - but there is no indication on the adapter. Which one is positive and negative? black and black with white stripe??? Does is matter?? I assume it does??
Thanks,
Rooney
Old 05-05-2009, 03:45 PM
Phife is on a distinguished road
Black with white strip is positive usually. If you have a Meter you could check it.
Old 05-07-2009, 01:04 PM
Thanks for the reply, Phife.
All I have is an analog meter.
Tell me if I'm wrong here.
Plug the adaptor in. Place one probe inside the end of the plug. Place the other on the sleeve of the plug. The inside or sleeve of the plug, whichever gives me a positive voltage reading with the red probe on it, is the positive.
Is this the correct procedure??
Old 05-07-2009, 01:08 PM
that is correct.
Old 05-07-2009, 04:04 PM
Thank You, Phife.
Need Help!- Kitamura Mycenter 1 480 volt to 240 volt conversion? mjrockwellus General Metal Working Machines 2 10-21-2008 11:14 AM
Need Help!- G53-Z SHIFT AMOUNT NEGATIVE coondog Daewoo/Doosan 3 05-16-2008 10:21 PM
Verification of negative posters rocket67 Suggestions for the CNCzone.com site. 8 11-23-2007 03:25 PM
Making a positive mold from a negative mold - how? SRT Mike Moldmaking 7 03-29-2007 04:30 PM
G83 + G72 with negative return plane drewmeister Haas Mills 2 02-20-2007 06:21 PM
