When you run steppers at their maximum recommended voltage, they'll get hot. Most steppers can run up to 180° without a problem. If you're not running the steppers as fast as they're capable of going, then a lower voltage supply may give you the same performance and much cooler motors.
LinkBack URL
About LinkBacks
