| Automation Technology Products Discuss Automation Technology Products here. |
Hi Everyone, This is the first time on this Forum and new to cnc. I ordered the CNC 3 Axis Package with 425 oz-in motor and KL-4030 Bipolar Driver with 36V /8.8A Power Supply, and I'm in the process of getting it all wired up but now I have a problem. As you see in the left side of the picture I have a 5V. power supply that shuts down every time I hook up the 5volts to the DB25. I disconnect it and it comes back on (it's an overload feature). I've checked all the wiring per there web site and all seems to wired right. I also installed the jumper wire JP1 to JP2 for the 5 volts. Has anyone else had this problem? Also are the motors supposed to (lock-up) with the power on? I'm using Mach 3 and have followed the instructions to the "T". Thanks |
| Hi Curtis. Welcome to the Zone!
A couple questions: Have you tried using the 5V "wall wart" that came with the kit? Do you have the En terminal powered with 5V or wired to E stop switch? It looks to me like you have the 36V power wires "daisy chained" from one driver to another. This is a NO NO and each driver should have 2 power wires running directly from Power Supply. Here's some info that might be helpful: http://www.cnczone.com/forums/showthread.php?t=76865.#3 CR. |
| here is the diagram for you http://www.kelinginc.net/KelingProductsDocuments.html |
| Thanks for your help, I didn't know about "daisy chaining" I will correct it. No I haven't tried the wall wart, the unit I'm using puts out 4.9 volts. As far as the E stop I'm using the Vista CNC pendent. Here's the link; http://www.vistacnc.com/ so the E stop isn't wired to the board As far as the EN terminal I'm sure what you mean. The documentation is surely pitiful to say the least and doesn't even come close to being descriptive!!!!! I can only guess at the dip switches on the driver?!?!?! 8 switches with only 6 settings. What do you do with #4 and #8 switch...nothing?? Thanks for your help, Curtis |
| This is what I'm talking about! Just looked at the link and here is what I see. KL 4030 #1 (from Kelinginc website) ENA+ ENA- STEP- STEP+ DIR- DIR+ KL 4030 #2 (from Kelinginc website) REST- REST+ (DIR)CW- CW+ (STEP)CP- CP+ KL 4030 #3 (the one I have) ENA- ENA+ (+5V) DIR- DIR+ (+5V) PUL- PUL+ (+5V) OK, so how do you wire this driver up again? @#?#?$ Now I'm totally confused?? |
| Please confirm that you have the 5V jumper set between #1 and #2 on the C-10.
CR. |
| Here's a manual for a drive simular to the 4030. Maybe this will help you some: http://www.leadshine.com/upload/1224656549834.pdf CR. |
| DB-25 wiring diagram: http://kelinginc.net/KL-DB25.pdf If you are NOT using an Estop switch, then pin #10 MUST be jumpered to GND. CR. |
#11
| blk is ground, red is 5V+ as shown on the PCB Thanks for your help C |
#12
| CR. |
| PCMCIA to DB9 to DB25 | adda | Machines running Mach Software | 4 | 05-29-2007 08:04 PM |
| 25p IDC to DB25 parallel | pzzamakr1980 | General Electronics Discussion | 1 | 11-15-2006 07:08 PM |
| Help. DB25 interconnect | RotorRouter | General Electronics Discussion | 6 | 04-22-2006 02:36 AM |
| USB to DB25 | wrloveyuelin | Mach Software (ArtSoft software) | 1 | 10-23-2005 11:45 AM |
| DB25 connector | TigerPilot | Stepper Motors and Drives | 2 | 03-20-2005 04:06 PM |
