| Automation Technology Products Discuss Automation Technology Products here. |
So I am getting back to work on my machine and just need a sanity check on this wiring. I think I am ready the Wiring diagrams right but just to be sure I have laid out most of the wiring on paper. Look it over and see if I have screwed it up in some way. I will be using the C10 BOB common pins as +5v to simplify wiring, if this is bad let me know and I will use bus bars for the 5v. I am going to use busbars for the 24v power to the drivers. Thanks Clicking the diagram takes you to a full size 3500x3500 image. |
| I guess no news is good news, I suspect if someone had spotted an error, you would have heard about it ![]() Al.
| It looks as though you have daisy chained the 24V PSU. If so, that should be changed to individual wiring to each drive. Do you mean you have set the Com jumper to make com 5V? That is only for Gecko drives. Keling drive should be com = Ground. CR. |
| If you are going to wire up the limit switches anyway, you might as well try it. MOST of this wiring would have already been done internally if you had purchased a G540. Just attach 2 power wires, motor cables, plug in the parallel cable and go. BTW: You have no charge pump, (G540 has one) so always be sure to have Mach up and running before you close the master enable switch. You don't want your axes charging around without control while the computer is booting up. Also, there is no opto isolation on a C10, (G540 has it) so you might want to use a separate PP adaptor rather than your computer's Parallel port. This way, the PP card will fry, not the whole computer. HMMM! Four $55 4030s plus a $26 low tech BOB plus $10 wall wart = $256. 299-256= $43. You gave up a lot of G540 plug & play, high performance and numerous other goodies to save that $43. If you ever want to control spindle speed from mach you will have to buy a ~ $40 card and will have saved nothing. ![]() CR. Last edited by Crevice Reamer; 04-06-2009 at 08:12 AM. |
| I would have bought the G540 if it had existed 1 year ago. All of these parts were purchased about 18mths ago. I had some real life issues come up, unemployed, and that kept me from working on my machine. So if I had to do it again I would purchase a G540. maybe for the second machine. Because it seems like everyone builds more then one machine. |
#10
So let's fire this thing up and get some cutting done. CR. |
| Starting to wire my Keling KL-4030 drivers...QUESTIONS! | BrassBuilder | Benchtop Machines | 22 | 07-20-2009 06:04 PM |
| Having trouble running keling 4030 drivers with emc2 | OneAndy | LinuxCNC (formerly EMC2) | 11 | 01-25-2009 07:03 PM |
| Need Help!- Keling 4030 losing steps? | jonmessenger | Automation Technology Products | 3 | 09-28-2008 12:21 PM |
| Microstepping drive-alternative to Keling KL-4030? | jakovn | Stepper Motors and Drives | 2 | 08-27-2008 05:41 PM |
| Need Help!- KL-4030 WITH GECKOS C1G BOARD WIRING HELP | rodmdx | Automation Technology Products | 1 | 02-11-2008 09:26 AM |
