Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 04-01-2009, 11:26 AM
PCcruncher's Avatar
PCcruncher is on a distinguished road
Power supply KL-150-24 24V/6.3A
If I have 3 steppers (1.76 v dc, 2A, 1.8*/step) and the hobby cnc Pro board, will this power supply work?
KL-150-24 24V/6.3A
http://www.kelinginc.net/SwitchingPowerSupply.html
or this one:http://www.trcelectronics.com/Meanwell/rs-75-24.shtml
Output Voltage: 24 Volts DC
Min Current: 0 Amps
Max Current: 3.2 Amps
Power: 76.8 Watts
Old 04-04-2009, 11:24 AM
PCcruncher's Avatar
bump
Old 04-04-2009, 12:33 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
KL-150-24 24V/6.3A
Min Current: 0 Amps
Power: 76.8 Watts
Hi PCcruncher!
The KL-150 will work fine. But for best performance, I would recommend either the KL-300-36 or the KL-320-36.
CR.
Old 04-04-2009, 12:49 PM
PCcruncher's Avatar
Thanks Crevice Reamer!
What are the advantages of the higher voltage?
those 2 you suggested have a better amp rating, the KL-300-36 is out of stock, so that would only leave me with the KL-320-36 36V/8.8 or 9.6A
Old 04-04-2009, 12:54 PM
Well you can always NOT use the extra amps. The PSU will only supply what the motors draw.
The advantage is in efficiency--More top speed, less lost steps. It's all explained in here somewhere:
http://www.cnczone.com/forums/showthread.php?t=76865.#3
CR.
Old 04-04-2009, 01:32 PM
PCcruncher's Avatar
Thanks for that link, I'll bookmark it
"Well you can always NOT use the extra amps. The PSU will only supply what the motors draw."
True, I wouldn't want the motors to be wanting more than the PSU can give.
Ordered the KL-320-36
-PCcruncher
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
power supply sa1 General Electronics Discussion 18 10-08-2008 12:22 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply elogicca General Electronics Discussion 3 02-23-2006 09:07 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
