Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 02-13-2009, 05:40 AM
escott76 is on a distinguished road
Dimensions for a Kelling 12.5A 48V power supply?
I've got one on the way, and I'd like to go shopping this weekend for an enclosure for it and some other stuff. Anybody got a set of dimensions handy?
Old 02-13-2009, 06:26 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Eric,
I believe Mean Well power supplies are the same as what Keling sells.
See the attached PDF
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-13-2009, 09:57 AM
Hirudin's Avatar
Hirudin is on a distinguished road
The one I got is 6.75" x 4.75" x 3.625". Those dimensions are the size of the box, the terminals stick out an additional half-inch or so making it roughly 7.25" long.
Old 02-13-2009, 04:36 PM
LUCKY13 is on a distinguished road
Dont forget you need room for air flow. IMHO you would be better off to wait on your enclosure purchase until you have all your system there so you can get a idea what you need. Of course good deals on boxes that would be over sized would not be a problem, but to small a box is a bad thing you want to try and avoid. You will be surprized at how much heat you will have to be dealing with. Put the machine in a hot closed shop and it gets worse.
Also these builds seem to take on a life of there own, before you know it there will be things you want to change, some expected and some not. Its best to leave youself a little growing room.
Jess
Old 02-13-2009, 09:17 PM
Jess
Thanks, I've done just a bit of wiring before, I'm pretty anal about neat wiring with plenty of room. I've scratch built tube amps before, so heat handling and large power supplies are kind of easy
Good overall advice, but knowing the dimensions gives me an idea of what to pick up.
-edit spelling
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Kelling servos used on Rutex drivers marting Automation Technology Products 2 09-20-2007 02:30 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
X3 With CNC Fusion Kit, Geckos, CandCNC MiniIO, Kelling Drives, etc. pzzamakr1980 Benchtop Machines 9 12-02-2006 10:09 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
