Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 01-28-2009, 05:43 PM
bbrown2005 is on a distinguished road
motor speed
hi
i have a kl23h2100-30-4bm motor with a 4030 driver and i was wondering what my top speed (rpm) would be with a 24 volt power supply and what it would be with a 36 volt while still having torque? thanks
Old 01-28-2009, 06:36 PM
ger21's Avatar
That's almost impossible to answer. there a a ton of variables involved, and you haven't provided any. First, you'd need an accurate torque curve for the motors using that drive at those voltages. How are you driving the machine? What's the efficiency of the drive system? How much weight are you moving? How fast do you want to accelerate? And many more.
Old 01-28-2009, 07:18 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
I can't say what your speed will be, but I CAN say:
Voltage = power. Power = speed. That internally wired Bipolar Parallel motor has a best power voltage of 76V. So if you were powering it with 76V and full step, you would get the top speed available. Twenty four Volts is only 32% of best power. 36V is only 47% of best power. But that's not all. Your driver does not have mid band resonance compensation and that will cause the motor to stall long before top speed. Any micro stepping will cut top speed even more.
Now if you dumped the 4030s and went with a G540 and 48V, you would definitely get a lot more speed.
CR.
Old 01-29-2009, 06:34 PM
thanks,
i have g201 also the 4030 came with the steppers and the 24 volt ps
i would like to up my power supply when i can get the money
Old 01-30-2009, 09:29 AM
If you use the G201 with a 72V PSU, Those motors will FLY. Even with the 24V PSU, the Geckos should give you more speed than 4030.
CR.
Old 01-30-2009, 09:18 PM
i hooked them up today and was able to increase my velocity by bout 5ipm thanks
motor speed thestruuus DIY-CNC Router Table Machines 4 05-01-2008 09:28 PM
servo motor max speed Bobbyr70 Servo Motors and Drives 1 11-11-2007 02:45 PM
Low stepper motor speed MagooT Stepper Motors and Drives 5 11-08-2007 10:10 AM
X2 Motor Speed dang Benchtop Machines 1 11-02-2007 03:40 PM
stepper motor speed AlanETM Stepper Motors and Drives 1 01-05-2006 09:17 PM
