Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 12-07-2008, 10:13 AM
Shanghyd is on a distinguished road
425 oz Stepper Wiring
Hi all,
I bought the 425oz motors from Keling but a board from another supplier.
I have the KL23H286-20-8B motors.
The wiring colors are as follows
Red, Red/White, Blue, Blue/White, Green, Green/White, Black, Black/White.
I have a driver board from dtllc.com.
http://www.dtllc.com/files/4XCNC10Brev1.pdf
The diagram for the driver board shows 4 wires from the motor connected to A, a, B, b.
The other 4 wires seem to go to V+.
Can anyone tell me the wiring connections?
Old 12-07-2008, 12:37 PM
BSawyer486 is on a distinguished road
Talking Wiring
Black/white and green together, Blue and red/white together. each or those pairs will go to seperate +voltage. Then your other four wires will go to your board as follows....
Blue/White connected to "A" terminal
Red connected to "B" terminal
Green/White connected to "a" terminal
Black connected to "b" terminal
Hope this helps
Old 12-07-2008, 12:52 PM
Thanks! Your the Man!!
Old 12-07-2008, 06:37 PM
Unhappy Correction
Ok, And this is why I dont offer help too often. Incase anyone else has the same or similar set-up, a correction needs to be made as follows....
The red wire needs to be connected to "a" and the Green/White wire gets connected to "B".
Sorry for the mistake.
Bruce
Old 09-08-2011, 10:13 PM
Mad Welder's Avatar
Mad Welder is on a distinguished road
Thumbs up
Originally Posted by Shanghyd View Post
Hi all,
As your motors are Hybrid it depends on what holding torque you need will determine what wiring config you select. If you look up the Keling website for your pdf motors specs it gives the exact wiring configs for all three Unipolar, Series and Parallel wiring configs. I have the 8 wired motors too and it gives greater flexibility providing your power supply can output the required amperage.
Eoin
Old 09-14-2011, 03:58 PM
Mad Welder's Avatar
Unhappy
Eoin
Oops my apologies for the confusion/mistake in my last post and I should have clarified and made the distinction that providing what output power your driver can supply will also make a difference in how you wire your motor.
Eoin
Eoin
Old 01-10-2012, 03:51 AM
GAWnCA's Avatar
GAWnCA is on a distinguished road
Hope this helps
I know this is an old post but let me tell you, you saved my behind by posting this way back when. You are the first poster that actually had the correct wire colors. Even Keling's data file was wrong. Thanks!
wiring for stepper redeft Stepper Motors and Drives 9 03-28-2007 09:02 PM
Stepper wiring monte55 DIY-CNC Router Table Machines 4 11-23-2006 05:04 PM
Stepper wiring glofuel Stepper Motors and Drives 5 02-15-2006 09:52 PM
Stepper Wiring JW Peters Stepper Motors and Drives 2 06-03-2005 07:17 PM
