| Automation Technology Products Discuss Automation Technology Products here. |
I Wired up my powersupply (48v 7.3) and when the switch is on 115 it puts out 65v whitch is too much for my G540. I switched to 230 and it puts out 45v (all running on 110. is there something wrong ? Is my switch backwards? |
I don't think I am making any sense![]() ![]() If it is a keling power supply, I believe that the power supply is a regulated supply and should output 48v as delivered.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| "48vac rectified and filtered will output 48v*1.414 = 68vdc" Does that mean that this poer supply: KL-600-48 48V/12.5A 115V /230V will power this Servo: KL23-130-60 Skewed Rotor Design, 60V/20A Constant Torque: 50 oz-in Peak Torque: 350 oz-in No load Speed: 4700 R.P.M Terminal Voltage : 60 VDC Continuous Current: < 4 A Peak Current: > 20 A No load Current: 0.5A Weight : 1.4 kg up to its max 4700rpm no load speed? I'm trying to figure out what gearing I need so I have to be sure that the power supply is up to the job of getting the servo up to its rated max rpm |
| How'd you supply your power supply? | cnczane | DIY-CNC Router Table Machines | 12 | 08-28-2011 05:13 AM |
| VFD as DC power supply? | Scott Kelley | Phase Converters and VFD | 10 | 07-29-2008 03:28 PM |
| More power from switching power supply | R.thayer | General Electronics Discussion | 4 | 03-10-2007 07:03 PM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 02:56 PM |
| Power supply | DLMACHINE | Servo Drives | 2 | 04-18-2004 03:56 PM |
