Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 10-18-2008, 09:33 AM
LUCKY13 is on a distinguished road
600in-oz servo motors ?
Would your 600oz-in servo motors be a good match for a Enco RF45 clone square column mill ( about the same size as a Industrial Hobbies mill) ?
I am ready to buy a kit for our conversion and dont know which servo's would be best. I am pretty sure the 1125oz-in motors you offer in your Nema34 kit is to big. I expect the 600 or 850oz-in motors will be best. The 600 runs at 6000RPM, the 850 runs at 4200RPM.
The 600oz-in motors should allow for a good gear reduction and plenty of resolution, but will it be enough torque ?
Do you offer the 600 or 850's in a kit form ? And which one would be best for a mill this size ?
The mill will be cutting aluminum and some lite steel with upto 6000rpm on the main spindle (veriable speed). But it will also have a high speed spindle added as a second spindle to do engraving.
I want to use the Gecko 320 drivers, and probably a C11 BOB and a Smooth Stepper.
Any help would be great.
Thanks Jess
Old 10-18-2008, 12:53 PM
Kelinginc is on a distinguished road
We can offer you the following package:
1: NEMA 34 Servo Motors 3 Axis CNC Kit:
A: 3 PCS Geckodriver G320, 80V/20A
B: 3 PCS KL34-150-90 (NEMA 34) Dual Shaft, 600 oz-in Peak
90V/40A
C: 3 PCS US Digital: E5S-500-250-EG-PKG2 Individually Packaged
Shaft-Mount Optical Encoder with latching connector, 500 CPR , fit
1/4" diameter shaft. Molded mounting ears for 1.812" bolt circle
(with Installation Tool) + 3 PCS 3131 Encoder Cables
D: 1 PCS KL-7220, 72V, 20A, Unregulated Power Supply
E: 5V Power Supply
F: 1 PCS C11G Breakout Board for 6 axis, Isolated signal, E-Stop or Limit
Switch can be wired
But email me at support@kelingicn.net if you have any question
Old 10-18-2008, 07:21 PM
Thanks for the reply, but I have tried E-mailing and it always kicks it back saying that "the destination computor not found" .
I have check address and its right but for some reason I cant get it though.
Jess
Old 10-18-2008, 10:29 PM
Jess
Try to send to kelinginc@yahoo.com or kelinginc@hotmail.com
www.kelinginc.net
Old 10-19-2008, 02:51 AM
TOTALLYRC is on a distinguished road
90V/40A
E: 5V Power Supply
Switch can be wired
Hey Keling, It looks like you mispelled your email address. I think it should end with inc, not icn. Hope this helps.
Time for more coffe.
Servo Motors Joseph Conrad General Electronics Discussion 0 08-12-2008 06:18 AM
Pluto Servo - Motors won't servo correctly???? TZak LinuxCNC (formerly EMC2) 2 01-10-2008 02:34 PM
DC motors as servo motors Doug Schwochert Servo Motors and Drives 5 12-26-2007 12:03 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
servo motors ? vertcnc DIY-CNC Router Table Machines 4 12-19-2003 09:53 PM
