Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 09-14-2008, 07:53 PM
bbrown2005 is on a distinguished road
stepper voltage
i have just got a kl34h280-45-4a and a kl-23h2100-30-4bm and was wondering what voltage these work best with and what is the max voltage? also about what is the top rpm they perform brst at thanks
Old 09-16-2008, 01:15 PM
Kelinginc is on a distinguished road
For kl34h280-45-4a and a kl-23h2100-30-4bm , you can use the power supply up to 80 DVC. The speed is up to your driver, power supply and setup in your control software
www.kelinginc.net
Old 09-16-2008, 07:53 PM
the nema 34 motor is run with a g201 the nema 23 motor is run with kl4030 i have a 36 volt power supply
Old 09-19-2008, 07:20 PM
i have it up and going and my nema 34 motor aint got as much torque as the 23 motor i have my current set to 5 amps on the 34 motor the motor temp runs about 128 degrees farenhieght when im running it but i can turn the motor without any effort i double checked my current set resistor with dvom to make sure it is the right size. any sugestions thanks ben
What voltage for bipolar stepper 2 A, 1 Ohm ? vroemm Stepper Motors and Drives 24 09-09-2010 01:03 PM
Stepper voltage jdholbrook Stepper Motors and Drives 1 02-23-2006 10:06 PM
Stepper / Voltage ckrantz Stepper Motors and Drives 10 10-03-2005 07:02 AM
Stepper motor Voltage metron9 Stepper Motors and Drives 3 11-15-2004 07:10 PM
Stepper voltage glentner General Electronics Discussion 7 03-29-2004 11:02 PM
