| Automation Technology Products Discuss Automation Technology Products here. |
Am I correct that there is no defined +/- on a 5V supply that you would plug into the wall? When I connect it to my BOB there isn't a specific wiring direction. In other words pick 1 and put it on the + and put the other on the -. Also does the low voltage side of the control system not have a ground back to the AC input or "earth"? |
| If the wall-wart/cube supply is DC output it has a + & - connection. They generally are isolated from ground, so if you NEED to reference it to ground, then you make a connection between - and system earth ground. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Do you have a multi-meter? If you don't have a means to measure, and have a simple diode on hand such as a 1n4005/6/7/ etc. You just insert the diode in series with one of the leads and the V5 term when you hook it up, the stripe end to V5 term. If the board works, mark the diode wire +5, if it does not, reverse the leads only (not the diode) and it should now work, and now mark the wire. Remove the diode and connect direct. Also make sure any Wall-wart you use is DC out, some are AC, it should be marked. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by Al_The_Man; 08-04-2008 at 01:09 PM. |
