Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 07-19-2008, 04:38 PM
GibbonsRock's Avatar
GibbonsRock is on a distinguished road
Grounding question!
Hi!
I'm wiring a Keling kit up and I have a question. Is it OK to connect all the grounds together from the 5v and the 36v systems? (The 5V is coming from the computer's USB)
Does it matter if I wire up the 36V power supply with two wires or three?
Sorry for the rookie questions, but I may have blown up a HobbyCNC board with a grounding issue, but HobbyCNC was not helpful in troubleshooting it, so now I'm pacing my steps carefully.
Thanks! -Jim
Old 07-19-2008, 06:20 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I'm pretty sure those grounds need to stay apart. I have a lab supply and it produces 2 x 32 VDC both with seperate grounds and it has another 5 VDC that is separate again.
You sure don't want your higher voltage PS having a common ground on the PC.
There are several ways and many theories on grounding, so you may get a different answer as well.
Lee
Old 07-19-2008, 09:25 PM
Al_The_Man's Avatar
The term ground and common are frequently mixed up and interchanged.
One does not necessarily mean the other.
There are two schools of thought, some specify complete isolation, i.e. all systems and power supplies kept separate by isolation.
The other where all components of a system, including all metalic objects/enclosures power supplies, shields, are connected to an earth point, common to service ground etc.
This is called uni-potential bond/grounding.
Once a method is selected, it should be carried out in the correct manner, many problems occur because one method or the other is not adhered to completely or correctly.
I prefer the latter because it is usually easier to achieve.
Old 07-21-2008, 08:39 AM
Very interesting. I asked because there are two wiring diagrams on Keling's website, and one shows all the grounds connected, and the other keeps them separate.
Grounding and Static Mrebeiro70 Laser Engraving & Cutting Machines 1 02-21-2008 07:50 AM
Table grounding millman52 General Electronics Discussion 3 10-12-2007 10:44 PM
Grounding question dmparrott General Electronics Discussion 2 08-23-2007 09:50 AM
Proper grounding monte55 Xylotex 13 12-05-2006 02:09 PM
grounding Q's anthony General Electronics Discussion 1 05-14-2005 06:24 PM
