Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 06-21-2008, 07:24 PM
oxford's Avatar
oxford is on a distinguished road
5056 red light
Is this wiring right?
KL23H286-20-8B
(bipolar parallel)
A BLU/WHT RED/WHT
A- BLU RED
B GRN/WHT BLK/WHT
B- GRN BLK
http://www.kelinginc.net/KL23H286-20-08B.pdf
I wired the drives to the steppers. The red LED by the PWR/Alarm is on now and the steppers are hard to turn by hand.
Also, when configuring in Mach 3, The drive is labeled with:
ENA
PUL
DIR
I figure that DIR and PUL are configured in the motor pins configuration for direction and step. (Are they active low or high?)
I am unsure about ENA though.
Thanks for the help
Old 06-22-2008, 04:31 PM
Kelinginc is on a distinguished road
http://www.kelinginc.net/KL-5042wiring.pdf
Do not connect 5V in your case
configue the Mach3 as follwoing
http://www.kelinginc.net/Mach3Tutorial.doc
Old 06-23-2008, 11:13 AM
oxford's Avatar
I tried disconnecting the 5v power supply from the driver but the red LED remains illuminated.
I tested my power supply at 47.8V. I tried lowering that to 43 v and turned it on again, but the red LED remained on.
Power supply KL-350-48 48V/7.3A.
Should I play around with the max Amp switches?
Also, I am unable to open the .doc file. Is there a place I can read it online?
Keling 5056 driver setup alexccmeister Automation Technology Products 9 04-19-2011 11:28 PM
Spectra light and Light machine owners have ? ZipSnipe Benchtop Machines 11 07-18-2008 10:52 PM
Need Help!- What cable between KL-5056 and 425oz? Georg Automation Technology Products 1 05-13-2008 02:44 PM
425 oz. Motors 5056 Drivers and new PSU Cartierusm Automation Technology Products 4 04-21-2008 03:37 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 09:08 AM
