Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
  #13   Ban this user!
Old 07-14-2008, 09:16 PM
Amedeo Muscelli is on a distinguished road
Originally Posted by Crevice Reamer View Post
The current will vary depending on RPM and load. At no-load and speed, current requirement is very little.
CR.
Hello CR,
In the holding positions the current is 0.3Amp, during the acceleration i get 0.4 to 0.5, making force by hand at F150 mm/min ( 6 inch/min ) 0.36Amp, forcing the motor reaching the axis limit I have 0.6 amp. If move the potentiometer and the other end the holding position is 0.140Amp. Nothing to do, this driver board offered for 2.5Amp only give 0.6 with a 282 Oz/inch motor at 36Volt, bipolar wired as series. The current was measured in the imput of the driver board, that mean than is measuring the current of the board and all the motor poles at the same time.
Regards,
Amedeo.
  #14   Ban this user!
Old 07-15-2008, 02:23 PM
Fiero Addiction is on a distinguished road
When I measured the current of my Keling drivers I measured the actual current through one winding of the motor with the motor holding at 0 rpm. It measured almost exactly to specification, but not consistently. I remember jogging the motor a few times, and each time it would stop I would get a different reading depending on the microstep position it stopped at, but the highest reading always matched the max current setting. I assume in full step mode the holding current would always be maximum driver current setting no matter where it stops. I could be wrong.
My Mechatronics board came from autohec on Ebay. I would to recommend anyone who is using this board, if you are not happy with the performance of your motors, get some decent drivers before changing anything else.
Jon
  #15   Ban this user!
Old 07-15-2008, 02:47 PM
GibbonsRock's Avatar
GibbonsRock is on a distinguished road
Hi Gang!
Thanks for the heads up Crevice Reamer. You're right- the package price is only about 20 bucks lower than the sum of the parts, so I just ordered what I need from Keling. Now begins the oh boy oh boy oh boy it's hard to wait phase.
Cheers, Jim
  #16   Ban this user!
Old 07-19-2008, 02:04 PM
Hey Gang,
I got my electronics from Keling yesterday and realized I neglected to secure a 5v power source. I have a Logitech wall wart rated at 6v and 400 mah; will that work or is that extra volt really too much for it?
Thanks! Jim
  #17   Ban this user!
Old 07-21-2008, 08:21 AM
Never mind- I totally overlooked that I can just grab the 5v off the computer's USB.
Cheers, Jim
Starting to wire my Keling KL-4030 drivers...QUESTIONS! BrassBuilder Benchtop Machines 22 07-20-2009 06:04 PM
Keling motors, drivers and power supply connections Nitroghost Automation Technology Products 14 03-13-2008 11:18 AM
Keling power supply? mcruff Automation Technology Products 5 09-23-2007 09:11 PM
Keling Inc. KL-8056 Drivers heathmanc Automation Technology Products 8 06-19-2007 07:54 PM
