Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 05-05-2008, 01:57 PM
MakotoKamui is on a distinguished road
Recommended PSU for a 4-axis setup?
Hi, all,
Currently, I've got a 3-axis Keling setup, http://www.kelinginc.net/ThreeXCNCPackage.html, and I want to upgrade to a 4th axis on my machine (using the same 4030 driver and KL23H286-20-8B 425oz stepper). Does anyone know if the included PSU will handle the added load of the 4th driver/stepper? If not, which should I go for as a replacement?
Thanks!
Old 06-03-2008, 01:15 PM
Thought I should post an update on this - I decided to stick with my current power supply, and try things out. I haven't done any major work with my machine yet, but the current PSU does seem to be handling the load of 4 motors and the fan.
However, I'm writing my own software to control the machine, and tend to run only 2 motors at any given time, just because of the way I'm doing things internally. I am able to run all 4 at once, but I've only tried for very short periods.
Your mileage for this PSU and 4 motors may vary, but things look positive so far.
Old 06-05-2008, 03:25 PM
Kelinginc is on a distinguished road
You can try it first. If it is not handling the motors, you can update to KL-3815, 38V/15A
http://www.kelinginc.net/SwitchingPowerSupply.html
Need Help!- Mach3 A axis (4th axis) setup? cadcamslawek Mach Software (ArtSoft software) 10 01-17-2012 09:23 PM
How do i setup my 4th axis on a maxnc? artur83 Safety Zone 0 04-15-2006 03:45 PM
Z axis setup MrBean DIY-CNC Router Table Machines 4 09-26-2004 12:55 PM
Z Axis Setup musicmkr DIY-CNC Router Table Machines 5 06-10-2004 12:33 AM
