| Automation Technology Products Discuss Automation Technology Products here. |
Hi John, I bought the 3 axis package with the 425 oz-in steppers, and I'm scratching my head over trying to follow your wiring diagram for hooking up the steppers to the 4030 drivers. The wiring diagram shows 8 wires from the stepper motor hooking into the driver. My steppers have only four wires, green, red, blue and black. I also noticed that the package on your web site shows that it has the KL23H286-20-8B stepper motor, while the package I received has KL23H2100-30-3B steppers, with the 3/8" shafts. The shaft size is fine, I just need to know where each wire plugs in on the 4030. Thanks, Mark |
| Maybe you should email or call him: Support: Support@kelinginc.net Tel: 630-254-8655 Fax: 847-850-0391 You might want to return those strange motors and get what you ordered. CR. |
| you can wire the 8 wire motors in either parallel config or series config. thereby giving you 4 wires to hook to the drivers. take a look at the pdf for the 8 wire motors and it will tell you haw to hook them up. i have the 8 wire motors too and used the series config. edit: oops just read that you have the 4 wire motors, so yeah you have it even easier now, but less options with the way you can wire it. no big deal. |
| Here is the wiring info: A + ---> Blk A- ----> GRN B+ ------> RED B- --------> Blue You can use your multimeter to check it If you need to learn stepper motor, here is some refrence http://www.cs.uiowa.edu/~jones/step/ |
#12
| Hi John and Khalid, Yeah, I'm alright now... ;-) I've been manually machining some of the parts I need for the CNC machine, and I haven't had a chance to finish up the wiring on the controller box. I should be able to have that portion done by the end of this week. Mark |
| new user confusion... | Spinnetti | Mastercam | 20 | 02-15-2008 07:41 AM |
| G52 confusion | davek | G-Code Programing | 2 | 09-08-2007 09:01 AM |
| confusion | serry | DIY-CNC Router Table Machines | 4 | 04-27-2007 07:40 PM |
| Z position confusion | baldysm | MadCAM | 8 | 02-16-2007 10:46 AM |
| Manual.doc vs. .ini confusion | medved | TurboCNC | 2 | 04-04-2006 11:18 AM |
