Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 03-20-2008, 03:14 PM
bluerobotkid is on a distinguished road
Question KL23H2100-30-4B Motor info needed
Hello,
I just bought the 3 axis package and I recieved these motors in the package. I am tring to set them up on my homade cnc router machine with single start acme rods and the antibacklash nuts from dumpster-cnc. What current setting should I use on the kelling stepper controller? What are the steps per revolution ( is it 200?) Any info about these motors would be helpfull. They look comprable to the motors I was expecting but have a larger shaft size (3/8). _Ben
Old 03-20-2008, 10:37 PM
gdb gdb is offline
gdb is on a distinguished road
Hi bluerobotkid,
I am using 4 of them on a 48" X 48" router. I run 60 volts and 3 amps.
They run 5 to 10 hrs. per day with no problems for about 6 months now.
200 steps per revolution. They seem to work best for me at 8 microstep.
gdb
Old 03-21-2008, 02:09 PM
Kelinginc is on a distinguished road
set driver to 3A, 8 microstep,
http://www.kelinginc.net/KLDriver.html
http://www.kelinginc.net/KL23H2100-30-4B.pdf
Mach3 set up:http://www.kelinginc.net/Mach3Tutorial.pdf
Lathe info needed kong General Metal Working Machines 2 06-01-2007 05:45 PM
sonceboz step motor info - needed dan20041 Stepper Motors and Drives 1 03-27-2007 09:33 PM
Info Needed Omron 500 W Ac Servo Motor robo_plasma Servo Motors and Drives 0 01-06-2007 07:30 PM
Info on EDM needed cjs83 CNC Plasma and Waterjet Machines 7 07-07-2004 07:38 AM
info needed turmite Machine Problems, Solutions , Wireless DNC, serial port 9 08-02-2003 02:28 AM
