Results 1 to 4 of 4
Thread: Breakout board - power light indicator?
    Jan 2008
    Hi, all,
    My 4030 kit just arrived on Friday, and I finally got a chance to start hooking things up this evening. Most of it went great, but I had a question - on the breakout board, next to the inputs from the 5V DC adaptor, there is an LED labelled "power". When I turn everything on, though, this light stays out.
    Now, I haven't tried hooking this up to my PC yet, as I'm slightly paranoid about that LED not coming on. Is this normal?
    (And just to verify - with the DC adaptor, the wire with the white dashes is the ground, correct?)
    Thanks for any insight!
    Jan 2008
    Finally got a chance to get back to this with my voltmeter, and it looks like I was wrong - white dashed stripe was the positive wire, contrary to some other posts I'd seen! The voltmeter says it's putting off around 6.5 V, so once I attached the leads correctly, all was well and my little power light lit up like a star.
    Which reminds me - I thought it was supposed to be a 5V power supply, not a 6.5. Will this cause trouble, or is it just an updated model?
    Apr 2007
    Hi my power supply is rated at 6V, i dont remember the actual output, I don't have the motors on the machine yet, but they spin just fine sitting on my desk so i think you are ok. I recieved my kit only a few weeks ago so its most likely the same power supply.
    Cheers, Dave
    Jan 2008
    Thanks for the confirmation - I hooked everything up, and my motors are spinning nicely as well.
    Happy building!
  1. what USB Breakout Board to by ??
    By dbss in forum General Electronics Discussion
    Last Post: 01-19-2008, 08:54 AM
  2. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-09-2007, 08:55 PM
  3. New breakout board
    By corydoras in forum General Electronics Discussion
    Last Post: 04-25-2007, 07:23 PM
  4. Best breakout board?
    By nate in forum Xylotex
    Last Post: 01-03-2007, 08:39 AM
  5. What is a breakout board?
    By andy_ck87028 in forum Stepper Motors and Drives
    Last Post: 08-28-2005, 06:37 PM
