Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 01-19-2008, 09:39 AM
ataxy's Avatar
ataxy is on a distinguished road
would like to get connection info for the 6050
could you send me wiring diagramm of the 6050 driver i would really like to have official info instead of doing guess work based on the other driver document
the reason is that i got my motor to turn but it simply wont stop as soon as i plug in the psu it starts to turn slowly but thats it, it just turn.
i did check my lpt port and it work fine with both a lpt printer and a loopback device
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 01-19-2008, 05:58 PM
Kelinginc is on a distinguished road
KL6050: Vcc+ to power supply, GND to Ground, You know how to connect A+, A-, B+,B- for motor. Dir+, Step+ to 5Vpower supply, Dir- and Step- is from your breakout board or LPT pin. If you have further question, pls email at support@kelinginc.net
www.kelinginc.net
Old 01-19-2008, 06:11 PM
ataxy's Avatar
directly to 5v power supply or tru the com port in between the pins 2 and 3 of the bob
Old 01-19-2008, 06:33 PM
Dir +, Step+ directly from 5v power supply source
Old 01-19-2008, 06:55 PM
ataxy's Avatar
ok well i think i definitly have a problem with the bob or else i am really dumb
so far i have
-checked for continuity the db25 cable all pin are straight true
-i have checked my lpt port with and old printer and a loopback device and all went fine
-tryed two of the driver you sent me
-tryed two motor you sent me
-tryed connecting only the bob to the computer to see if i would get low and hi signal when changing direction on the pin but i get a constant hi no mather what
-hooked up everything, that is computer-bob-driver-motor-48v psu-5v psu the only thing that happen is that since i get a constant high from the bob the motor starts turning and does not stop as soon as i connect the 48v psu
-i tryed connecting the setup to all the set of output pin so 2-3, 4-5, 6-7 and both way so dir-step or step-dir while always making sure i had set it right in ports and pin of mach
-i do get signal from the input since i did try to set an e-stop on all the input pin and mach react each time to its presence
i have been going true it since last night on the yahoo mach3 group to no avail unhooking and hooking back everything but i just dont get it its a no go
http://groups.yahoo.com/group/mach1m...BjSWQDODU0Mzc-
edit: i do get a fluctuation of the 5v when i chage direction with mach but it only goes 5.1 - 4.7 and back to 5.1 if i change direction again
Old 01-19-2008, 08:23 PM
Give me a call, I will help you. or email me your phone at support@kelinginc.net, I will call you.
Old 01-19-2008, 09:18 PM
ataxy's Avatar
sorry if my message came out bad it was not my intention, so to anybody who reads this this post the guy is really a good guy and does offer really good after sale follow up whe did figure that the c10 board was the problem and all is fine i will for sure do business again with keling for futur upgrade on my machine or other machine i intend on buying
again i am sorry if this came out like i was mad i was just going crazy trying to understand why it was not working
What is NC NO connection? mealman General Electronics Discussion 4 10-15-2007 06:59 AM
Connection bbrreid Mazak, Mitsubishi, Mazatrol 5 07-15-2007 04:13 PM
Fanuc 6050 Servo Drive thebighorn General Metal Working Machines 0 04-24-2007 02:05 PM
Internet Connection? CNCadmin CNCzone Club House 0 05-25-2003 01:35 AM
