| Automation Technology Products Discuss Automation Technology Products here. |
ok i am trying to hook my first motor but it does not work here is how its hook up tell me if this is allright edit: i am using mach3 also when i start mach3mill it tells me that driver are initialized and the motor shaft is locked if i use the jog function the dro moves but the motor does noting no humming or hissing nothing port & pin is set to 2 and 3 as it is hooked on the bob edit2: ok i took a look at th diagram on this website wich are better then the one keling have, graphic wise, and notice that the +5 going to the driver should be comming from the bob and not straight from the 5v psu so i have hooked it to the com beetwenn the 2 and 3 screw but still i am unable to get movement from the mach3 interface edit3: ok i ran the driver test it reports fine and i have only small jitter on the line from time to time also i have noticed something weird mach3 seem to change my step pin i had it set to 2 and 3 and now sometime it will change it to 16 or 13 or 15 but always something in the 1? the dir pin will stay on 3 edit4: i have tryed setting the bob jumper for the com from gnd to +5 but no change the other jumper on the c10 bob is set to 2-9 as output edit5: ok i dont know if this could be the problem but i have notice this morning that there is a small puck on the outer casing about 3/8 long by 1/4 at its widest and about 1/16 at its deepest so ill try the other motor to see if this could be the cause edit6: ok well i hooked up the other motor but i am not getting any movement from this one i have left a message on ther phone monday and one today so i guess i should have a return call soon! ill send them a email to just in case
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne Last edited by ataxy; 01-16-2008 at 11:18 AM. |
| You need to config the Mach3 also. pls check here http://www.kelinginc.net/Mach3Tutorial.pdf |
| ok thx for the call i guess ill move my problem to the mach forum since the problem is between mach and my pc
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
| VFD terminal hook up help | 9 1/2 | Bridgeport and Hardinge Mills | 17 | 01-10-2008 06:46 PM |
| cat 5 network hook-up for DNC ???????? | krfrea | Computers and Networking | 3 | 10-15-2007 08:53 AM |
| C-Hook programing | Russler | Mastercam | 1 | 01-14-2007 09:56 AM |
| How to hook up FSD2U2P12 driver(Japan Servo Motor) to computer? | happytriger2000 | Servo Motors and Drives | 2 | 05-28-2006 10:59 AM |
| C Hook | Graphcon | Mastercam | 5 | 01-11-2005 02:06 PM |
