I have double checked everything and my wiring appears to be correct according to the Keling specs. When I move the x axis via Mach3 it always turns clockwise no matter what commands I give it. I have 2&3 on the breakout board going to the driver. My second motor which is supposed to be the Y axis operates under the Z commands and only turns counter clockwise. I have 4&5 going to it. I can not make my third motor turn at all. It has 6&7 going to it.
Should I have to change any of the jumpers on the breakout board or are they set correctly when shipped?
give me a call, or send me a email support@kelinginc.net for your phone, I will call you.
I will help you to find the reason. Are you new?
