Results 1 to 5 of 5
Thread: 425 oz. Motors 5056 Drivers and new PSU
    Dec 2006
    I have keling 425 oz. motors on a working CNC router that I built. I bought a package from Keling with a 24V power supply and the 5056 drivers. Everything works fine and it's directly connected to my lead screws and in Mach3 I'm running at 40 IPM.
    I bought a 48V power supply from keling thinking it would do me one better, but now I'm confused.
    What will the 48V power supply do differently than the 24V? I think I have the 24V 8.3 amp and the new one is the 48V 5 amp. I just noticed he has a new power supply with 7.3 amps. Am I going to run into trouble with only 5 amps running 3 motors?
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by Cartierusm View Post
    The 5056 will accept up to 50V. The motor will accept at least 80V. (4.17V*20) Higher voltage causes much faster coil saturation per pulse, so 48V PS should at least DOUBLE your rapid speeds. The three 2.8A motors need at least 5.5 Amps, (.65*(2.8*3)) which is pushing the envelope of your 5A PS, so you might be better off with the 7.3A supply.
    CR.
    Feb 2008
    HelloCarthesium,
    i am build a simillar machine as you described. I am still using the evalution copy of Mach 3 software and Lazy Cam. I bought the same stepper motor package, and think the power supply is my weakest link right now. I was hoping to get at least 80 ipm and I am closer to 35 than 40. What setup info are you runing in Mach 3 and what microstepping are you using? Thanks - Ben
    Dec 2006
    10 microstep. Read my other post about Keling and Power Supplies
    Kelinginc for steppers and controller
    Oct 2005
    Hi Ben
    How did you tune the motor? You should get more than 70 ipm. Check here for Mach3 set up:
    http://www.kelinginc.net/Mach3Tutorial.doc
    • The step resolution of the motor drive, if you set at 8
    • The thread pitch of the screw. (How far the table moves with each rotation
    of the screw) let us say it has a 5TPI pitch.
    So Step per should be 200 x 8 x 5 = 8000.
    Send me your question to support@kelinginc.net
    1. Keling motors, drivers and power supply connections
      By Nitroghost in forum Automation Technology Products
      Last Post: 03-13-2008, 12:18 PM
    2. Stepper motors, drivers etc
      By _taz_ in forum Stepper Motors and Drives
      Last Post: 08-05-2007, 07:49 AM
    3. Using printer motors and drivers
      By NeoMoses in forum General Electronics Discussion
      Last Post: 04-07-2007, 08:42 PM
    4. Good controller/drivers for Nema42 140vdcmax 8a motors?
      By Vikketsi in forum Stepper Motors and Drives
      Last Post: 02-01-2005, 12:43 PM
    5. Help with motors\drivers
      By wired in forum DIY CNC Router Table Machines
      Last Post: 01-03-2005, 12:17 PM
