Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 11-02-2007, 09:02 AM
Nitroghost's Avatar
Nitroghost is on a distinguished road
Keling motors, drivers and power supply connections
I have 3 425oz motors and 3 5042 drivers with 1 36v power supply. i am a little confused about the connections on the drivers. i have a motor connected to the driver with no problem. i have 1 wire connected from the driver to the breakout board. that is about all i can under stand from the wireing diagram located here http://www.kelinginc.net/KL-5042wiring.pdf. i am not sure what the box is called that is to the right and just below the breakout board that has a "- + 5 volt" in it. also how do i connect multiple wires to 1 slot on the beakout board? Any idea?
Jim
Old 11-02-2007, 11:57 PM
rustamd is on a distinguished road
5V box is 5V supply, there probably was small transformer that came with your order. There should be two wires going from BOB to drivers. Pin 2 and 3 for X axis, 4 and 5 for Y, etc.
Not sure what you mean by connecting multiple wires to 1 slot? Each wire has its own connection, at least on the diagram.
Old 11-03-2007, 06:53 PM
Nitroghost's Avatar
ok. i have the 5 volts that is needed and i have the motors,drivers and the power supply connected exactly and the diagram showes. When i put power to the system i still hear the motors enguage and i still hear them hissing. I just can't make the motors move. I have configured Mach3 and have watched the tutorials for setting it up. I have the software loaded on a windows 2000 system and have reloaded Mach twice now. Nothing i do can make the motors move. Am i leaveing anything out?
Jim
Old 11-03-2007, 07:23 PM
can you post picture of your wiring? and mach 3 ports and pins screen with input tab visible .
Old 11-04-2007, 12:57 PM
Nitroghost's Avatar
IT WORKS IT WORKS. it was an incorrect jumper setting on the breakout board. I still need to tune the motors because it is slow, very slow. i guess that is because i am useing 1/4 inch all thread instead of the acme ones. just need more money i guess. But IT WORKS
Jim
Old 11-04-2007, 09:37 PM
6 feet of ACME is $6.99 at enco, I'm sure you can collect that in one day if you dive under seats in few cars
Old 11-05-2007, 08:00 AM
Nitroghost's Avatar
(hmmm where are the keys to my wifes car?) I think i can handle that. I am not sure all i'll need any suggestions for a newbie?
Jim
Old 11-05-2007, 12:05 PM
Jim
It helps if you are able to take a seat out, find more that way, tell wife you cleaning
Old 11-05-2007, 12:53 PM
Nitroghost's Avatar
Good idea.
what should i look for when i get the ACME lead screws? my setup is 24'' X 48'' and is made out of 3/4 MDF i have never used the "good stuff".
Jim
Old 11-05-2007, 05:46 PM
I would use dumpster antibacklash nuts and 1/2" rod. Is this what you are asking?
  #11   Ban this user!
Old 11-05-2007, 06:28 PM
Nitroghost's Avatar
kinda i have 1/4-20 allthread and skate bearings for all three axises. Is that all i will need and will it work with 3/4 MDF?
Jim
  #12   Ban this user!
Old 11-13-2007, 09:08 PM
pump is on a distinguished road
Jim
Hi there, I am having axactly the same problem, can you be a bit more specific about the jumper setting an what the axact problem was,
Cheers.
Keling power supply? mcruff Automation Technology Products 5 09-23-2007 10:11 PM
Keling Inc. KL-8056 Drivers heathmanc Automation Technology Products 8 06-19-2007 08:54 PM
Steppers, Drivers and Power supply robertg991 Stepper Motors and Drives 21 05-21-2006 10:03 PM
Enable connections on drivers metalhacker Stepper Motors and Drives 6 06-12-2005 02:43 AM
