Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 06-13-2007, 08:10 PM
watsonstudios is on a distinguished road
Wiring done,firing up the system
I think my wiring is complete.
Other than making sure the wiring is correct, are there any precautions I should know about before I fire it up? Any particular order in turning on power? Should all the motors be connected or can I test individually? If I have only one motor connected to one driver, should I disconnect power leads to the other drivers or will it be fine?
I set the 4030 drivers to 1.2amp and 1/8 step for testing - (I really don't know what they should be set at yet)
I don't want to blow anything up the first time I power up.
Jump in with any words of caution.
Thanks.
Old 06-14-2007, 01:32 PM
rustamd is on a distinguished road
power the computer up first, make sure bob is connected, than power up your 24v/5v supplies. Shouldnt matter if you have one or 4 motors connected, i ran with only two and everything was ok. I have mine set at 3A. Good luck
Wiring help watsonstudios Automation Technology Products 4 06-13-2007 12:32 AM
wiring it all together russell General Electronics Discussion 2 08-22-2006 10:08 AM
CNC wiring? stdly General Electronics Discussion 11 02-18-2006 03:44 PM
system Wiring diagram, BMI Trak W/LCD needed bsllc Bridgeport and Hardinge Mills 5 02-17-2006 04:18 PM
P5 Wiring tintruder Servo Drives 2 02-03-2006 12:13 PM
