Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 06-12-2007, 09:02 PM
Larken is on a distinguished road
Gear head for Size 34 motors
Can you get precision gearheads for the size 34 servos? I would want about a 4-1 ratio. I think these would be popular items .
Larry K
Old 06-12-2007, 09:23 PM
rustamd is on a distinguished road
You mean like harmonic drive? I imagine it would be very expensive to properly design and make them, espesialy with no backlash... IMHO
Old 06-12-2007, 09:30 PM
if you google "nema 34 harmonic drive", quite few choices show up, but not cheap i imagine.
Also try searching for:
nema 34 frame harmonic drive
and also search for planetary gearhead...
Old 06-13-2007, 08:51 PM
Smitty911 is on a distinguished road
Yup they have them
Applied-Motion.com
Just ordered a 27 to 1. It should be here this week.
A little over $1,000.00 each one though.
Smitty
Old 06-14-2007, 12:50 AM
Originally Posted by Smitty911 View Post
Applied-Motion.com
Smitty
thats quite a bit more reduction that 4:1 is
Old 06-14-2007, 09:30 AM
I knew that.
But they also have the a full range of reductions. 1-4, 1-6, 1-27, ++++
Smitty
Old 06-14-2007, 03:24 PM
Smitty, If space is a problem, gearheads often are a good solution. If you have room, other less expensive methods are available. I've used them before and as often as not, I had problems with them. Remember, they have small gears with tiny teeth and itsy-bitsy bearing parts in them. Good quality is required. As I said, some did work. Think of the high quality planetary gears running in well lubricated automatic transmissions. Just don't try to tow a trailer full of bricks with a compact car with an auto tranny.
DZASTR
Old 06-16-2007, 08:51 PM
Stepper Monkey is on a distinguished road
You should check Ebay, they often have new planetaries in the box for two or three hundred dollars. A lot of 34 size go off cheap, often new. Size 23 are more in demand, but even at that I have some new ones I'd let go for a few hundred as well, even zero backlash harmonic drives. Takes some looking but there are some good deals out there from a number of surplus dealers.
Old 06-17-2007, 06:17 PM
routerman is on a distinguished road
MCG has some for around $500 each
http://www.mcg-net.com/gearheads/gearheads.html
But Keling may be able to import cheaper ones from china.
Old 06-18-2007, 09:46 AM
Kelinginc is on a distinguished road
Thank you all. I am working on it. I will post on my wensite when I get them
What size boring head should I buy? Kevin Harpham Metal Working Tooling 2 02-09-2007 05:55 PM
noise level of 3600 RPM motor with gear head Runner4404spd Industrial Hobbies (Support forum) 10 12-10-2006 02:42 PM
what size stepper to move head? Runner4404spd Industrial Hobbies (Support forum) 36 09-07-2006 03:01 PM
Ball Screw Jacks and Encoded Gear Motors gtslabs Linear and Rotary Motion 2 02-24-2006 10:05 AM
