Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 02-22-2007, 12:50 AM
Glidergider is on a distinguished road
Driver question about CW/CCW mode available (optional)
John,
I have a question about your drivers. The specs for the drivers indicate:
"CW/CCW mode available (optional)".
What does that mean, imply?
Dave
Old 02-22-2007, 05:01 PM
Kelinginc is on a distinguished road
The pulse can be set as clockwise or counter - clockwise.
Old 02-25-2007, 08:20 PM
Kelinginc,
check your PMs. I've got more questions. What do you mean????? Of course your product will turn CW -AND- CCW! That's a feature??? Please expand on your answer.
Dave
Old 02-25-2007, 08:33 PM
I'm two shakes from making and order and I want to order your product. I'm evaluating HobbyCNC and Xylotex. Please help me decide why I should choose a Keling system.
Old 04-06-2007, 07:28 PM
mar999 is on a distinguished road
cw ccw
: Im pretty sure it has to do with if you running encoders which way it supposed to be turning so if it looses a step it will know
Old 04-06-2007, 09:29 PM
Gold Member
Mariss Freimanis is on a distinguished road
There are two standards, Step/Direction and CW/CCW.
The more modern one is Step/Direction. You send a Step pulse to the drive, it samples the state of the Direction signal at instant of the active Step edge and decides from that which direction to take the step.
The other standard is CW/CCW. If you want to turn a motor CW, you send step pulses on the CW input. You want to go CCW, send step pulses to the CCW input.
CW/CCW is not as popular as Step/Direction for two reasons:
1) Both channels have to be wide-bandwidth while Step/Direction needs only one wide-bandwidth channel. The Direction channel changes state infrequently.
2) CW/CCW is ambiguious. What happens if you send steps to CW and CCW simultaneously? It's undefined. Step/Direction is unambigious.
Mariss
Old 04-07-2007, 12:55 PM
Xerxes's Avatar
Xerxes is on a distinguished road
I have a bit different opinion about CW/CCW vs step/dir.
1) Both channels of step/dir needs to be high bandwidth if short direction set-up time is required. CW/CCW don't have set-up time or post-hold time troubles at all.
2) "What happens if you send steps to CW and CCW simultaneously?". They cancel each one out, no motion should happen.
However, the best is quadrature mode input. It requires low bandwidth and every edge produces motion.
Old 04-07-2007, 01:28 PM
Gold Member
The CW/CCW interface was developed for the 74193 counter. Both inputs 'low' is illegal for that counter.
You can operate any Step/Direction drive with quadrature inputs if you want to.
Mariss
Old 04-07-2007, 01:53 PM
Oldmanandhistoy is on a distinguished road
I have just bought a drive with the CW/CCW option (not Kelin) and am wondering what benefit it would give if any? Is it as already stated to be used with encoders?
Thanks,
John
Old 04-07-2007, 02:01 PM
Gold Member
CW/CCW does not work with quadrature inputs. Step/Direction does. CW/CCW is primarily for legacy (read obsolete) applications.
Mariss
  #11   Ban this user!
Old 04-07-2007, 02:06 PM
Mariss
Thank you Mariss as always you are a wealth of information.
Regards,
John
  #12   Ban this user!
Old 04-07-2007, 03:18 PM
Xerxes's Avatar
No, quadrature to step/dir will not work properly because every edge is not counted. Counter value starts drifting if position jitters at single "step" edge.
CW/CCW can be done properly using two separate up-countig counters and then do substraction on the two sums. Historical or not, it is good :-)
Avoid Loading New Billet On Optional Stop Joey Mazak, Mitsubishi, Mazatrol 12 01-19-2007 08:55 AM
Stepper driver question ? msnarouz Stepper Motors and Drives 0 10-29-2006 09:16 AM
M6R5 driver question Bill Davis Stepper Motors and Drives 1 02-17-2006 07:03 PM
optional parameters for 3T joachim Fanuc 0 02-17-2006 01:18 PM
Block look ahead bypasses M1 optional stops Paul_S Haas Mills 0 03-08-2005 12:37 AM
