| Automation Technology Products Discuss Automation Technology Products here. |
I received a power supply Model KL 7220 without any docs. All output wires on the transformer are yellow and I'd like to know what they are in case I decide to use the transformer elsewhere. Thanks. |
| If you can power up the primary, first identify & separate all windings by resistance check, Then power up and take AC voltage readings of the identidied windings. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Document is on line. Pls check here http://www.kelinginc.net/KL7220.pdf. If you have any question, send me a email |
I've bought a keling 7212 power supply. It has red and black wires on the transformer, and the documentation on it tell me how to combine them for 110v. The problem i am having is, The power supply doesn't tell me what to do with the red and black wires once i have twisted the ends together (so to speak) Where do i conenct them to? And for that matter, How is power supposed to get from the wall TO the transformer in the first place? The transformer also has green wires, but the instructions dont say anything about it. And there are blues wires on a terminal strip attacked to a small circuit board (with the capacitors) but, alas, it does tell me anything about any other wire except the red and black, and that if you put them one way, its ready for 110 and the toher is 220. So...... Any input from anyone? I am really confused on this one. I don/t know where to attack a power cable (you know, from the wall) to the power supply. I dont know what the red and black wires are supposed to go to, nor the green wires, nor the blue ones. This has really been my chokepoint. I can't test anything because i don't have the power up yet. |
Pls check on this specification: http://www.kelinginc.net/KL7212.pdf for 110V 1: 2 red wires for netural 2: 2 black wires for hot 3: pls do not touch the blue and green wires, they are connected for you www.kelinginc.net Last edited by Kelinginc; 09-10-2007 at 10:11 PM. Reason: add more |
If you take a close look at the picture, the green wires are only connected on one end. the blue wires go from the coil to the ac input, and the red and black? Forgive me for asking the mos simple of question. Do I take my negative, or my positive wire and connect it to the red wires? are you SURE the green wires don't need to be connected to anything? Thanks for the quick reply. |
| Hi Both red wires for netural Both black wires for hot Do not touch other green and blue wires. It is configured by manufacture www.kelinginc.net |
#10
I purchased a KL-300-36 36V/6.6A power supply and didn'r get any doccumentation. There are 3 Com connections and 3 +V connections on the power supply. I have smoked a driver board because i didn't check for the proper connections (my fault). Is there any doccumentation i can get to show me how to correctly connect the power supply to the driver board? Jim |
#11
#12
Jim |
