Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 12-29-2011, 12:28 PM
Jkountz is on a distinguished road
Power Supply requirements
I have picked a motor package with a total of amps if 22.5. That is I have two motors with a max of 6.1 and two motors with a max of 5. Im assuming that a 20 amp 50v power supply will be enough since its not a good idea to run the motors at their max amp anyway? So If I were to run the larger motors at say 5 amps and the smaller motors as say 4 each, then the 20 amp supply would be good no?
Im trying to figure out this whole amp/volt thing.
Old 12-29-2011, 01:51 PM
Bubba's Avatar
Bubba is on a distinguished road
According to Mariss, a good sizing for a power supply is 67% of the aggregate requirement. So in your case this would amount to ~17-18 amps so the power supply will be adequate. The theory being that you will not be running all motors at max simultaneously all the time.
Art
Old 12-29-2011, 03:03 PM
Thanks Bubba, that reduces my total cost by a few dollars which is always a good thing!!
Old 12-29-2011, 04:03 PM
Zaggy is on a distinguished road
Unregulated linear PS
Funny enough, I was considering this alimentation today to equip servos :
https://www.antekinc.com/details.php?p=303
it could probably fulfill your needs. And for $20 less you have the 16A model.
Look at the PDF, it can be equiped with daughter boards offering (un)regulated 5V/12V/24V.
Hope this helps.
Zaggy
Rebuild Hurco Power Supply w/ PC Power Supply VMX30 jex mfg HURCO 13 09-16-2011 04:59 PM
Need Help!- Power Supply and motor requirements tizdall DIY-CNC Router Table Machines 10 01-01-2011 12:40 PM
Newbie- Servo and power supply requirements? LazyMan Servo Motors and Drives 4 08-01-2010 07:37 AM
Need Help!- Real power supply requirements Walky General Electronics Discussion 6 12-02-2009 08:05 PM
New VF2 and air supply requirements joesimmers Haas Mills 35 01-25-2007 10:53 PM
