Results 1 to 5 of 5
Thread: Will this power supply be sufficient?
    May 2010
    Im confused on how the whole current from power supply to stepper driver is handled.
    Im looking at the 48v 7.3a power supply with 3 of the KL-5042 drives. The motors Im powering are from Probotix and are these:
    http://www.probotix.com/specs/HT23-280-8.pdf
    http://www.probotix.com/specs/HT23-400-8.pdf
    I will be most likely running them in bi-polar series as most of my drive system is roller chain and sprocket, so High speed isnt needed. But I would like to be able to try to run in parallel if the need arises. Will this power supply be sufficient or will I need to go to the 48V 10A?
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    why not check cncrouterparts?
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    May 2010
    That doesn't really answer my question, And also I don't want to spend 300$ on a gecko drive when I can get the Keling drives for 120$ right now. So Back to the question, will that amperage be sufficient or do I need to go for the higher amperage PSU?
    Gold Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by prcdslnc13 View Post
    The 7.3a supply will be fine.
    I run (3) kl6050's parallel with (3) 5a 570 steppers with that supply no problem.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    May 2010
    Why thank you Hoss, that was exactly what I was hoping for.
    1. Replies: 13
      Last Post: 09-16-2011, 05:59 PM
    2. controller power supply 115/230v OK for Australian power?
      By Momill in forum Australia, New Zealand Club house
      Last Post: 07-07-2011, 12:06 PM
    3. Sufficient cooling to stepper drivers?
      By jaru-eri in forum DIY CNC Router Table Machines
      Last Post: 12-27-2008, 06:11 PM
    4. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
    5. One ballrail for the y- axis is that sufficient
      By belgrado in forum Linear and Rotary Motion
      Last Post: 12-03-2005, 12:13 AM
