Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 08-30-2011, 07:29 AM
Gold Member
RomanLini is on a distinguished road
Keling Size34 motor axial load specs?
Hi, I was reading in another post about someone wanting to use Size34 motors to drive leadscrews directly with no axial thrust bearing.
Does anyone have the specs for max axial load for the Keling Size34 motors? I checked a couple of PDFs on the Keling web page but didn't see axial or radial load specs...
Thanks!
Old 08-30-2011, 07:31 PM
LUCKY13 is on a distinguished road
Here is the specs for a motor I feel sure is the exact same as the Keling 850oz/in 90v servo. Its close enough to give you the info you need even if there is slight difference.
http://www.automationexpress.com/Pro...df/ID33003.PDF
Axial and radial specs are down at the lower section of specs.
Hope this helps, Jess
GOD Bless, and prayers for all.
Old 08-31-2011, 06:23 AM
Gold Member
Thanks for the link, but that is the old style round motor and has the very low maximum axial load spec (10lb) showing it uses the wave preload washer as the only thing opposing axial thrust.
I'm pretty sure the newer "hybrid" frame motors have the new style locking ring on the front bearing and Keling seems to stock the new hybrid motors.
Thanks again for your reply, but hopefully someone has data on the actual Keling motors?
Old 08-31-2011, 09:00 PM
You must being talking about stepper motors? The link I gave is a match to the 850 90v servo's I got from them. Although its been about three years when I buoght mine so they may be older style also. Sorry couldnt help.
Jess
Old 09-05-2011, 07:47 AM
Gold Member
Thanks anyway Lucky13.
I'm still hoping someone from Keling can speak up, I am interested in buying some size 34 double shaft steppers from the Keling web site but it's a lot of money to take a chance on the axial load specs.
I have seen specs from other manufacturers that show about 130kg axial load, because thos size34 steppers had the locating ring in the front bearing to locate it axially in the front motor plate. It's not something that can be seen without pulling the motor apart and that is not recommended, so it needs to be specified in the datasheet or manufacturer specs for the motor.
If anyone knows more, please speak up!
Newbie- Motor specs dipakkadam_619 Stepper Motors and Drives 11 12-23-2009 06:08 PM
Newbie- Motor specs mindspread Stepper Motors and Drives 0 07-10-2008 08:44 AM
Help with motor specs? ScreaminnSterio Stepper Motors and Drives 3 02-16-2006 11:14 PM
motor specs? miljnor General Electronics Discussion 0 02-28-2005 09:49 PM
Looking for some motor specs Snipes44 General Electronics Discussion 10 10-30-2003 09:14 AM
