Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 07-03-2011, 12:00 AM
mluis is on a distinguished road
voltage on phases of KL 4030
Hi to all!! i am newbie on stepper world, i have questions about stepper driver KL 4030 with keling 36 V power supply(set for full step and 2.7 A). I have a PIC16F84A that send the pulse/dir signal to the kl 4030 driver, when i push a button the stepper (keling 425 Oz-in in bipolar parallel) make 2 turns in full step mode, when stepper is static after turn, i measure the voltage on A+ A- and B+ B-and only one phase is active. i think it should be both phases active, because holding torque is low. Can i really take the 425 oz-in from kL 4030 when stepper is on zero RPM?
do you have voltage in both pashes on your KL 4030 when stepper is static?
i think that sequence signal for the coils for full step muts to be :
Full step for mx holding torque
step A B C D
1 +Vcc Gnd +Vcc Gnd
2 +Vcc Gnd Gnd +Vcc
3 Gnd +Vcc Gnd +Vcc
4 Gnd +Vcc +Vcc Gnd
Active both phases at same time
help me please because i think the problem is my driver i want to prove that...
thanks!!!
Luis
Old 07-03-2011, 09:32 AM
doorknob's Avatar
doorknob is on a distinguished road
I do not have any direct experience with that driver, however stepper motor documentation such as Jones on Stepping Motor Types shows that you can get full stepping with a power sequence having either only a single winding active at any time, or with both windings active at the same time. Both windings active gives a higher torque.
So your driver may be operating as designed.
Old 07-03-2011, 01:45 PM
thanks for response!!
Then I think this driver do not give the max torque because is only single phase at the same time. so what driver could work with both phases sequence at full step mode?
Berger Lahr 5 phases motor/driver units AlainB Stepper Motors and Drives 3 02-16-2012 10:42 AM
Need Help!- Confused about phases.... MaNo General Electronics Discussion 8 06-03-2009 10:07 PM
Help..Stuck at relay ext dc voltage missing but dc voltage OK ? Dirky Bridgeport and Hardinge Mills 24 11-27-2007 07:33 AM
How many phases make a useful stepper? andy_ck87028 Stepper Motors and Drives 5 11-26-2005 08:43 PM
stepper motor load resistor and figuring out phases? drtuto General Electronics Discussion 7 03-19-2005 02:53 PM
