Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 06-12-2011, 09:50 AM
ViperTX is on a distinguished road
KL6050 can it fail just a bit?
Okay,
Have not used my X3 with CNCFusion and Keling Steppers and Drivers for about 4 months.
I lubed everything, Homed the System and zeroed the X and Y and referenced the Z with Big-Tex.....just as I normally do.
Loaded my g-code file, hit Cycle Start and the system went to the tool change position, hit Cycle Start again and all the axis start moving the tool bit towards the workpiece.
Problem is that the Y-axis sounds funny. Sounds like the stepper is not moving properly. Stopped it and checked the Y-Zero and sure enough it is off by 1/2 inch.
Loosed up the y-axis jib screws and it still does the same thing.
I reset the system and set the slow jog to 10 on the Mach3 Tab flyout....moved the table back and forth on the y-axis and in 4 passes the y-axis is off by 1/8 of an inch. X and Z are correct.
Tried one of my old working files and the y-axis does the same thing after the tool change....it loose position.
Without swapping the KL6050 drivers, has anyone seen this problem?
Thanks,
Paul
Old 06-12-2011, 10:53 AM
jalessi's Avatar
jalessi is on a distinguished road
Question
Paul,
Have you thoroughly cleaned and re oiled the way's and lead screws lately?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-12-2011, 11:55 AM
Jeff,
Yes, that is the first thing I did.
The ballscrews look like the day I first installed them. The ways and jibs are clean and oiled.
Paul
Old 06-12-2011, 12:35 PM
jalessi's Avatar
Paul,
How is the lead screw alignment, have you tried turning it by hand to see if there is binding anywhere along its travel?
Jeff...
Old 06-12-2011, 02:35 PM
Jeff,
I can easily move the y-axis by rotating the coupler.
When the y-axis was running sounding funny...I even loosened the y-axis jib screws and it made no difference at all.
Fast jogging the y-axis it moves just fine.
Paul
Old 06-12-2011, 02:44 PM
jalessi's Avatar
Paul,
Swapping the driver with either the X or Z would help isolate the problem, ten minutes rearranging the wires might give a bit more insight.
Jeff...
Old 06-14-2011, 12:07 AM
Jeff,
Well I swapped the drivers and the problem follows the driver. Guess these drivers can partially fail.
Paul
ATC Cycle Fail Waiting on Air GM81 Fadal 5 04-20-2011 04:48 PM
Solid CAM Fail mr chris SolidCam 3 01-05-2011 03:24 AM
Problem- 325 PROC WDT FAIL ramsey321 Tree 15 09-14-2010 10:47 AM
VF2 Turrent Fail jimmck Haas Mills 1 06-03-2009 11:50 AM
Lube Fail CC714 Fanuc 2 01-24-2008 10:39 AM
