Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 02-12-2011, 12:09 PM
Kelinginc is on a distinguished road
Digital Stepper Motor Driver Exprience
Hi
Pls write your comments here for Digital Stepper Motor Driver KL-8056D, KL-5056D,KL-4042D.
Old 02-13-2011, 10:16 AM
Thanks les
I move your copmment to here:
Les Foster
Keling's New Digital Drivers
For anyone interested in the new digital drivers, they are amazing for reducing if not eliminating resonance noise in my system, 11 ft screw at 12" ipm. Thanks Keling
Les
Old 05-28-2011, 01:51 PM
hellenic is on a distinguished road
Digital Steppers save the day
I built a 4-axis cnc router and I used two motors slaved together for the x-axis. The resonant frequencies when I moved the x-axis had me completely baffled. I wasn't sure if the problem was mechanical or not. The noises occured at exactly the same points and only in one direction. It varied on each side of the x-axis. I wished that my x-axis sounded like my y-axis. It stunk because I knew that my machine was well built but anybody watching it work would think otherwise. I took a chance and purchased the digital steppers from Keling. WOW! Total silence when I moved in the x-direction! It worked beautifully. The x-motors were so quiet that I decided to switch out the analog drivers for my y and z axis. My a-axis driver sounds ok, and I think it is because it is a newer technology Keling analog driver. I designed and built my CNC from scratch and to have it work this well first time around would not have been possible without John at Keling or Greg at Warp9 for that matter.
Old 05-28-2011, 04:01 PM
The digital driver has better perfromance, lower noise, less heating, smoother movement , eliminating resonance noise.
Check here
Digital driver
Old 06-01-2011, 05:23 PM
Originally Posted by Kelinginc View Post
Check here
Digital driver
another Comments from James
"By the way I like the KL-4042D digital drivers"
Old 06-02-2011, 02:53 PM
Kencor1 is on a distinguished road
Noise introduced in home switch
I just received 1 KL-8056 Driver and tried it out on my X axis. It worked great I was able to double the speed without the motors stalling. I am using nema 34 from Keling. The problem that I am having is that I am getting a lot of noise introduced into my Z axis home prox switch. When I home the z axis it hits the switch just barely starts to back off and stops, the led on the diagnosis screen for that input will flash radoml, but the led on the switch it self stays on and never comes off. When I swithced the driver back to the Keling KL-8078 everything goes back to normal. Does anyone have any ideas for me to try to fix this? I already tried uping the debounce to 2000 no help. I also am using a smoothstepper and a c-10 BOB.
Thanks,
Tom
Old 06-20-2011, 08:09 PM
LUCKY13 is on a distinguished road
I would post this in more of a electronic section, I think you will get more guys that can answer it without a doute.
I think it is a simple fix but I dont want to steer you wrong by mistake.
Jess
Old 07-01-2011, 02:14 PM
Milton is on a distinguished road
A little calculation help
I need some calculation help to see if what I would like to do will work.
I am looking at this stepper motor.
Stepper Motor
Max RPM on motor is 1,000 RPM
Now if I have it geared to 3-1 between motor and screw drive and the screw drive is 5 turns per inch, Will this raise and lower a unit that weighs 1,000 pounds if ran at 25% of max speed.
Milton
Stepper Motor
Old 07-26-2011, 10:04 PM
Gold Member
planescott is on a distinguished road
KL-5056D Drivers
Thanks Keling, I bought the 5056D drivers. They are super nice.. silky smooth, quite . I will never buy another analog driver again.... Thanks Again!!! Scott
Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A guy2b1 DIY-CNC Router Table Machines 16 03-08-2011 05:50 AM
Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board wf1318 Stepper Motors and Drives 2 07-25-2010 02:19 AM
Integrated stepper motor? with built-in stepper motor driver uirobot Product Announcements & Manufacturer News 0 06-07-2010 03:59 AM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 04:56 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 05:05 PM
